Script cannot be enabled #87545
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
2 Participants
Reference: blender/blender-addons#87545
Operating system: Deepin 20.2
Graphics card: Mesa DRI Intel(R) HD Graphics 520 (Skylake GT2)
Broken:
blender-2.93.0-2cc3a89cf60d-linux64 && blender-2.92.0 && blender-2.91.2
1.Open the Blender 2.93 Reference Manual
2.Add the following script to the Text editor in Blender
3.Click the Run Script button
3.Open the Operator Search menu and type in “Move X by One” (the bl_label)
4.Click to disable script, it will report an error
error code:
RuntimeError: unregister_class(...):, missing bl_rna attribute from 'RNAMeta' instance (may not be registered)
Added subscriber: @fn930211969
Added subscriber: @rjg
You seem to be doing something different than your instructions state as the script is installed as an add-on. Just by running the script from the text editor won't make it appear in the add-on preferences.
It seems the steps you've actually performed were:
frist.py
and then manually saved it toblender/2.93/scripts/addons
frist.py
into the text editor.Is that correct?
Hi, thank you for answering the questions for me in your busy schedule. First of all, you questioned that my operation process is incorrect, but the same process is no problem on the windows platform (I have tried it)! Or you are sending me the correct operation process, I need to confirm it, thank you.
@fn930211969 What I meant is that the screenshots you've added don't match the description of your steps. It seems that you have installed the add-on first, hence it's visible in the preferences, and you are running it from text editor as well. By running the same script in the editor you would try to register the operator a second time, which will cause trouble when trying to deactivate the add-on that originally registered the operator. The steps I've posted result in the error you're describing in your report and I would like to know if those are the steps you've actually taken.
Yes, my main problem is that I can’t find this custom script in Operator Search, even though I have enabled and loaded this custom script
In order to find operators that haven't been added to any menu, you need to enable Developer Extras in the preferences. See blender/documentation#87180 for detailed instructions.
Thank you, I have solved the problem。
Changed status from 'Needs User Info' to: 'Resolved'
