Default View Transform for "General" Start Up Becomes "Standard" Instead of "Filmic"
Closed, ResolvedPublicBUG
Graphics card: NVIDIA GeForce MX130/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.11
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-04-15 14:16, hash: rBa4877f9e5408
Worked: 2.92
Not really sure if this is a bug. I cannot think of the reason why you would change the default back to "standard" like 2.79, and I cannot seem to find relevent posts, so I am reporting this just in case.
Based on the default startup
  1. Load Factory Setting if you have custum startup
  2. Look at View Transform under Color Management Panel, usually it is "Filmic", but now it is "Standard"
Alaska (Alaska) changed the task status from Needs Triage to Confirmed.Apr 16 2021, 11:07 AM
Alaska (Alaska) changed the subtype of this task from "Report" to "Bug".
Alaska (Alaska) added a subscriber: Alaska (Alaska).
Can confirm.
I bisected the issue and found it to be caused by rBac90c8a7743f: UI: Add a workspace for geometry nodes in the default startup file
I believe it's just a mistake.
Ugh, I guess that comes down to saving the startup file in a non-full build. Changing the startup file is sketchy, yikes.
I'll change that back.
It should be fixed now. Thanks for the the report @Zijun Zhou (Eary), and the bisect @Alaska (Alaska), and the poke @Philipp Oeser (lichtwerk) : )
