bump node in Blender 2.81 not working
Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
Alaska (Alaska) closed this task as Archived.Sat, Apr 17, 12:26 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).
This report does not contain all the requested information, which is required for us to investigate the issue. However, I would first suggest trying a newer version of Blender to see if it would help:
2.92: https://www.blender.org/download
2.93 and 3.0: https://builder.blender.org/download/
Please submit a new report and carefully follow the instructions. Be sure to provide system information, Blender version, the last Blender version which worked, and a .blend file with exact steps to reproduce the problem.
A guideline for making a good bug report can be found at https://wiki.blender.org/wiki/Process/Bug_Reports
