Mirror bisect plane scaled in object space rather than mirror object space? #87592
Reference: blender/blender#87592
Operating system: Linux
Graphics card: Intel
Broken: 2.92
When an object which has a mirror modifier using
use_bisect_axis
andmirror_object
also has some degree of rotation and anisotropic scale across the mirror axis, the bisection plane appears in the wrong place:It looks like the bisection plane is being offset in the object's space instead of in the mirror object's space.
Add a cube and an empty to an empty scene.
Add a mirror modifier to the cube.
Set
mirror_object
on the mirror modifier to the empty and enable "X" foruse_bisect_axis
.Rotate the cube by any non-orthogonal angle around the global "Y" axis.
Scale the cube by any significant amount around its local "X" xor "Z" axis.
Or just download and open the below file:
ObjectBisectFailure.blend
Added subscriber: @WCN
Added subscriber: @filedescriptor
I can confirm this on the latest 2.93.0 Beta, branch: master, commit date: 2021-04-19 10:12, hash:
c75b2019e1
.Changed status from 'Confirmed' to: 'Archived'
After taking a closer look, I found that the cube object had a non-uniform scale. Applying the scale solves the problem.
The bisecting could maybe take the scale into account, but this would not classify as a bug (unless it worked in a previous version).
Closing this for now.
@filedescriptor Anisotropic/non-uniform scale is explicitly a part of the description and reproduction steps. Applying the scale doesn't solve the problem so much as avoid it, and isn't an option for objects with shared data.
The bisecting already does take scale into account— Just not always correctly. If you scale the object uniformly in the axes that intersect with the mirror plane (so Z and X but not necessarily Y in the example), then the bisection plane stays at the world-relative center and angle of the mirror object. Likewise, if you rotate or translate the object, the bisection plane also stays at the correct place. It's only with non-uniform scale along axes which intersect with the mirror plane that the behaviour suddenly changes from how it behaves with all other transformations.
Note too that the actual mirror plane itself also stays at the world-relative center and angle of the mirror object. It's only the bisection plane that becomes separated from the mirror plane (which, in and of itself, is also a thing which should probably never happen).
The expected behaviour of the mirror modifier is for its mirror and bisection planes to be positioned at the same position and angle in world space as the mirror object.
A corollary of this is that the bisection plane should never be separated from the mirror plane.
This issue describes a reproducible scenario where that expected behaviour is clearly broken. Why would it not be classified as a bug?
Added subscriber: @ideasman42
I looked at the code as it currently is and this is working as intended. That's why I would say it is not a bug. The scale is just not taken into account. And the fact that uniform scale is working is just a by-product of how matrix multiplication works.
@ideasman42 Would you say we should classify this as a bug?
I know I'm just a user with an opinion.
But the tooltip for the "Bisect" options says "Cuts the mesh across the mirror plane". And this is a scenario where it does not cut the mesh across the mirror plane. Even if the behaviour was somehow originally intended, it still clearly defies both documentation and reasonable user expectation/utility.
Changed status from 'Archived' to: 'Confirmed'
@WCN I agree with you that this is confusing. I will reopen the report and mark it as a to-do. There is no good reason, why the bisection is affected by the scale of the object.
This issue was referenced by
1e16662de8
73af884df0
