Curve Bug Whener you press CRTL + Z (Undo Command)
Graphics card: AMD Radeon(TM) Vega 8 Graphics ATI Technologies Inc. 4.5.14757 Core Profile Context 20.12.1 27.20.14501.28009
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Whenever i undo too many times while using the Premade Curves it bugs out not letting me enter to edit mode on any Curve object
but it does let me enter on other types of objects just not curve
Unable to execute 'Toggle Edit Mode', error changing modes
Open Blender, CRTL + A (add a Object) - add Curve Object named "Path" - Select the path you Created (NurbsPath) - enter to edit mode - select the Last Dot - Press E (extrude it) - Right click - enter back to object mode - CTRL + Z (Undo) - "Repeat" - Extrude E (the Dot) - Right Click - Enter Back to Object Mode - CRTL + Z - "Repeat"....
bpy.ops.curve.primitive_nurbs_path_add(radius=1, enter_editmode=False, align='WORLD', location=(0, 0, 0), scale=(1, 1, 1))
bpy.ops.object.editmode_toggle()
bpy.ops.curve.extrude_move(CURVE_OT_extrude={"mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(0, 0, 0), "orient_type":'GLOBAL', "orient_matrix":((0, 0, 0), (0, 0, 0), (0, 0, 0)), "orient_matrix_type":'GLOBAL', "constraint_axis":(False, False, False), "mirror":False, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, "use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False, "use_automerge_and_split":False})
bpy.ops.curve.extrude_move(CURVE_OT_extrude={"mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(1.92011, 0, 0), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), "orient_matrix_type":'GLOBAL', "constraint_axis":(True, False, False), "mirror":False, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, "use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False, "use_automerge_and_split":False})
bpy.ops.curve.extrude_move(CURVE_OT_extrude={"mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(1, 0, 0), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), "orient_matrix_type":'GLOBAL', "constraint_axis":(True, False, False), "mirror":False, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, "use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False, "use_automerge_and_split":False})
bpy.ops.curve.extrude_move(CURVE_OT_extrude={"mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(2, 0, 0), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), "orient_matrix_type":'GLOBAL', "constraint_axis":(True, False, False), "mirror":False, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, "use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False, "use_automerge_and_split":False})
bpy.ops.curve.extrude_move(CURVE_OT_extrude={"mode":'TRANSLATION'}, TRANSFORM_OT_translate={"value":(0.681279, 0, 0), "orient_type":'GLOBAL', "orient_matrix":((1, 0, 0), (0, 1, 0), (0, 0, 1)), "orient_matrix_type":'GLOBAL', "constraint_axis":(True, False, False), "mirror":False, "use_proportional_edit":False, "proportional_edit_falloff":'SMOOTH', "proportional_size":1, "use_proportional_connected":False, "use_proportional_projected":False, "snap":False, "snap_target":'CLOSEST', "snap_point":(0, 0, 0), "snap_align":False, "snap_normal":(0, 0, 0), "gpencil_strokes":False, "cursor_transform":False, "texture_space":False, "remove_on_cancel":False, "release_confirm":False, "use_accurate":False, "use_automerge_and_split":False})
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Mon, Apr 19, 9:45 AM
I seems a bit weird that you can extrude [which would mean you are in editmode], then toggle editmode three times [which would mean you are in objectmode], and then are able to extrude again [this should only be possible in editmode].
At this point it is unclear to me which ones are "real" editmode toggles and which ones belong to UNDO.
If I simply follow the steps as in the report desription I am in objectmode when the next bpy.ops.curve.extrude_move folloows [which is not possible because context is incorrect as stated above]
Could you share a file that is in that state?
A video showing how this is happening might also help.
Philipp Oeser (lichtwerk) closed this task as Archived.Mon, May 3, 6:20 PM
