Debug build BM_mesh_triangulate() will hang forever if mesh face count is high. #87625
Reference: blender/blender#87625
Operating system: Xubuntu 20.04
Graphics card: NVidia K5100M
Broken ONLY WITH
Debug
build: Blender 3.0.0 Alpha (It should have been broken way earlier)Worked only with
Release
and 'RelWithDebInfo' build: Blender 3.0.0 AlphaShort description of error
The call to
BM_mesh_triangulate(bm, quad_method, ngon_method, 4, false, NULL, NULL, NULL)
does not exit on some bigger meshes. Specifically, it seems to have been stuck insideBM_face_kill(bm, faces_double->link);
.(if you call it with bmesh
op
andslot_in/out
arguments it will run properly)Exact steps for others to reproduce the error
On my machine the bucket runs fine with subdiv levels 1-2 and above 3 the bug shows. The subdiv value in that file is 3.
Note that the bug is only reproducible in
Debug
build. Seems that function doesn't like meshes that has face count higher than a certain amount...My guess would be there's a lot of checks in debug code path in the function, somewhere it reaches a case where the memory pool gets corrupted. It never quits, in the task manager, memory doesn't show any changes at all. (It's way below my 32G system memory so it can't be there being not enough memory).
Since this triangulation call is related to sculpt as well so I'm gonna ask if this happens to @PabloDobarro in debug build...
0_rouge_bucket.blend
Added subscribers: @PabloDobarro, @ChengduLittleA
Added subscriber: @ankitm
It's not stuck as in a lock or a freeze. It's doing the work in the first
#ifndef NDEBUG
section ofBLI_mempool_free
.That explains it being a problem in debug build.
Added subscribers: @Sergey, @dfelinto
@Sergey you added this (the NDEBUG code in BLI_mempool_free) 8 years ago. Care to comment on this?
After 20 minutes, Blender becomes functional again.
@dfelinto, clearly that was a way to catch issues with misuse of memory pools, to ensure only addresses from the pool are freed.
You can move the check inside of
if (UNLIKELY(mempool_debug_memset)) {
(maybe call the flag more explicit). But you should also check that the pool is used properly. The fact that the code shows up in the profiles means that there are a lot of chunks, meaning, pool might not be really saving up on allocations. It might be all fine, but that's what you need to check.Changed status from 'Needs Triage' to: 'Confirmed'
