Single bone unable to have weighting between 0 and 1, can only be 0 or 1 due to normalization #87714
Reference: blender/blender#87714
Graphics card: NVIDIA GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 465.89
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
When weight painting, the weight doesn't always get used. Repeating the same action a few times is required, despite the visual representation of the weight map.
Open a default scene
Add an armature
Parent the default box to use the armature, using envelope weights.
Paint the bottom of the box with zero ( blue ) weight, so that the bottom four vertices should not move.
Pose the armature, you'll notice that the vertices do move.
Repeat the painting a few times, and it will eventually work.
BlenderArmatureWeightPaint.mp4
Added subscriber: @MalDuffin
Someone tested and confirmed that this works fine on Linux, so it could be a platform issue ( this happens on Windows, I had 6 other people have the same issue while doing some online training yesterday ).
WeightPaint_cube_rig-292-N01.zip
Try to move the armature, the whole cube moves. Check the weight paint on the cube, the bottom vertices are painted blue ( should have zero weight, and not move )
On todays build of Blender 2.93 beta.
It seems that the vertex only stops moving when it is exactly 0. The other values ( eg 0.008 ) keep moving as if they were 1.
Added subscriber: @vasiln
Should probably be closed. Not a bug, just normalization of weights in the presence of a single bone. See conversation at https://blenderartists.org/t/is-weight-painting-broke-for-windows-set-of-steps-to-check/1300271 for more if you want.
Weight Painting Bug - Simple Exampleto Single bone unable to have weighting between 0 and 1, can only be 0 or 1 due to normalizationHi Nathan,
I changed the topic from...
to
Now that the issue has been narrowed down, it is a bug.
In my case, I'd like to assign half-weights to some of the vertices controlled by a single bone, and am unable to.
Added subscriber: @Helge-4
I just checked out the above blenderartists.org thread. This issue might be something to think about for the usability folks around here...
However, if you just want to somehow make this work, you could set the bone's Vertex Group within the Armature Modifier's settings. This way you should be able to control the bone's influence on each vertex.
Hi Helge,
Many thanks for looking into it and for the suggestion, I’ll try it later on when I’m at the computer.
One code based solution might be to not normalise totals under 1. I get why they are normalised for totals over 1, although there are cases where the user might want this to occur.
If 3 bones have weight on the same vertex of eg 0.25, 0.5 and 0.75 these add up to 1.5 and currently get normalised. That’s fine, you can assume the artist would most likely want this, so that the total control over the vertex is 1. The bones would end up with the same relative influence over the vertex.
If the 3 bones are set by the artist to have weights of 0.1, 0.15 and 0.2 to have a small influence over a vertex, the total is 0.45. This is under 1, and should not be normalised.
In the same way, if an artist sets a single bone to have a weight of 0.1 over a vertex, this is under 1 and should not be normalised. They very likely want to have this small influence over the bone.
The above change would allow an artist subtle control with weight painting. Hope that makes sense!
Added subscriber: @OmarEmaraDev
Thanks for the report, but the issue reported here is a request for modified/improved behavior and not a bug in current behavior. Closing as this bug tracker is only for bugs and errors.
I can see you already suggested this on RCS: https://blender.community/c/rightclickselect/mrhbbc/?sorting=hot. So lets track that suggestion there instead.
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
