GPencil: GPencilStrokePoints.weight_get throws an "index out of range" error for Vertex groups IDs with no points assigned #87790
Reference: blender/blender#87790
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-04-21 20:15, hash:
0f66dbea90
Create a Grease pencil stroke.
Create a vertex group
In a text window create a new file and run the following script
Added subscriber: @maumemoli
Added subscriber: @antoniov
The python api is not designed to check if the data is valid or not, just try to get the data.
I have checked and the first message is: "Groups: No groups for this stroke" The reason is the stroke hasn't any group, only the object.
If you assign a weight to the stroke, then you need pass the correct index. If the index is incorrect, you get the mensaje: "GPencilStrokePoints: index out of range"
This is the underlying C code:
BKE_report(reports, RPT_ERROR, "GPencilStrokePoints: index out of range");
return -1.0f;
weight = gps.points.weight_get(vertex_group_index=0, point_index=i)
print(i, weight)
i += 1```
GPencilStrokePoints.weight_get throws an "index out of range" error for Vertex groups IDs with no points assignedto GPencil: GPencilStrokePoints.weight_get throws an "index out of range" error for Vertex groups IDs with no points assignedI understand what you mean and I think it should work that way
Now my question is on how I can check if the strokePoints I am iterating are assigned to a vertex group without getting any error.
I guess it is complicated to have the vertex groups values available in the strokePoints as it is for vertices.
Shall I just use a "try" and let it continue if there is a exception?
Any help is really appreciated.
Added subscriber: @lichtwerk
As soon as any point has a weight assigned, the unassigned will return a value of -1.0.
Only if none is assigned at all, you'll get the
Error: Groups: index out of range
.So you are probably best of doing a check prior to the loop if any points are in the group [try/except is not nice, but possibly your best friend here].
Then if that check succeeds, you should be able to loop over all points (and the ones returning -1.0 weight are not assigned).
Mesh vertices have the
groups
property (https://docs.blender.org/api/master/bpy.types.MeshVertex.html#bpy.types.MeshVertex.groups) which can be utalized in similar mesh cases, maybe that should be implemented for stroke points at some point, I would not consider the current behavior a bug though, will archive for now (of course feel free to comment again if issues persist).I agree with you Philippe,
this is more of a feature request. I guess I will go with the try, except solution.
Thank you for the help.
