Cycles X - Restoring Features
Confirmed, NormalPublicTO DO
None
Brecht Van Lommel (brecht)
Mon, Apr 26, 5:18 PM
Tokens
"Love" token, awarded by bruce55."Love" token, awarded by baoyu."Love" token, awarded by kivig."100" token, awarded by PetrT."Love" token, awarded by Maged_afra."Love" token, awarded by Roggii."Burninate" token, awarded by HEYPictures."Love" token, awarded by Upliner."Love" token, awarded by harvester."Love" token, awarded by Alaska."Love" token, awarded by MetinSeven."Love" token, awarded by someuser.
  • CUDA GPU host memory usage (missing estimation of memory used by integrator and kernels)
  • Shadow catcher
  • Volume rendering
    • OpenVDB volumes
    • Mesh interior volumes and volume stack
  • AO pass
  • Shader ray-tracing (bevel, AO node)
  • Tiled rendering for very high res images (but not for performance tuning)
  • Multi-device rendering
  • Burley SSS?
  • Baking
    • Light baking (add init_from_bake and use regular integrator kernels)
    • Data baking (dedicated kernels)
  • Cryptomatte postprocessing
  • Save buffers
  • CPU profiling stats
Brecht Van Lommel (brecht) changed the task status from Needs Triage to Confirmed.Mon, Apr 26, 5:18 PM
Brecht Van Lommel (brecht) created this task.
Tjurig added a subscriber: Tjurig.Mon, Apr 26, 6:22 PM
Please keep Burley, Random walk in it's current state is very finicky and not reliable for all looks. The color doesn't converge to the correct one at very small radii, it's hard to exclude parts from affecting others except by separating meshes as different objects (other render engines let you exclude parts from each other in the shader), the sharp edges are not always wanted, and so on and so forth.
Octol added a subscriber: Octol.Mon, Apr 26, 10:42 PM
