Rainbow hair #87914
Closed
opened 2021-04-29 14:03:39 +02:00 by Ezma Ali · 5 comments
  • rainbow
  • hair
- rainbow - hair
Ezma Ali self-assigned this 2021-04-29 14:03:39 +02:00
Author
Added subscriber: @LILLLYISNOTLILLY
Author
This comment was removed by @LILLLYISNOTLILLY
*This comment was removed by @LILLLYISNOTLILLY*
Added subscriber: @rjg
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read this guide , it may help you write a bug report that allows us to identify the cause of the problem.
If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance https:*blender.stackexchange.com/ , https:*blenderartists.org/ or the [ https:*blender.chat/channel/support | #support channel on Blender chat . The bug tracker is only for bug reports.
In case you believe that you've found a bug, please create a new bug report through Help > Report a Bug in Blender. We expect all bug reports to follow the submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
Thank you for your report. Unfortunately, it does not contain the requested information that we need to investigate the issue. Please read [this guide ](https://wiki.blender.org/wiki/User:Rjg/HowToBugReport), it may help you write a bug report that allows us to identify the cause of the problem. If you need help learning or using Blender, please post a question on one of our [community websites ]], for instance [[ https:*blender.stackexchange.com/ | Blender's StackExchange ]], [[ https:*blenderartists.org/ | blenderartists.org ]] or the [[ https:*blender.chat/channel/support | #support channel on Blender chat ](https:*www.blender.org/community/). The bug tracker is only for bug reports. In case you believe that you've found a bug, please create a new bug report through *Help > Report a Bug* in Blender. We expect all bug reports to follow the [submission template ](https://developer.blender.org/maniphest/task/edit/form/1/). Please provide **system information** (operating system, GPU, graphics driver version), **affected Blender version**, previous **Blender version that worked properly**, a **short and precise description of the issue**, step by step **instructions to reproduce it** and, if relevant, **a minimal .blend file that showcases the problem**.
2 Participants
Reference: blender/blender-addons#87914
