3D Print Toolbox fails to calculate correct Area for object with mesh - triangulation error #87930
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#87930
Operating system: win10
Graphics card: rtx2080ti
Broken:
2.79b release, example: 2.83.5, blender3.0
Worked: None
I remember this bug since 2.7x, but I also met it in 3.0:
If object mesh data has some edges dissolved and non-flat topology,
using Area Statistics from 3d-Print-Toolbox addon Analyze panel
shows different result for base and triangulated with modifier object.
In mesh_helpers.py at line 27 bmesh_copy_from_object function have triangulate=True by default and at line 56 bmesh should be triangulated.
So I can't figure out why bmesh ain't triangulated and area incorrect as result.
Based on the attached .blend file (as simple as possible):
With 3D Print Toolbox calculate areas for both base and triangulated objects.
3d-Print-Toolbox AMI.blend
Added subscriber: @RUben
Added subscriber: @Sergey
Removed subscriber: @Sergey
Added subscriber: @OmarEmaraDev
I can replicate that. And I hit an assert during triangulation, so this could be related.
The script is missing the
bm.transform(obj.matrix_world)
step, which is why it doesn't hit the assert and might be different.Added subscriber: @lichtwerk
Note: flipping normals makes a difference, too (should not be the case I think)
Changing the
quad_method
orngon_method
doesnt seem to make a difference https://docs.blender.org/api/3.2/bmesh.ops.html#bmesh.ops.triangulate
