Crash when switching render slots while render is in progress
Operating system: macOS-11.3-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5500M OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.4.17
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-05-01 15:22, hash: rB7c5e00965533
Worked: 2.91.2
When a render is in progress, if I press J a few times to cycle between render slots, Blender wil crash.
Default scene
Switch from Eevee to Cycles
Press F12 to render
In the render view, press J to switch render slots a few times while the render is in progress; Blender will invariably crash after doing this a few times (sometimes up to 10-20 times, sometimes faster).
Crash log:
I just want to say that I can reproduce this issue on Linux with a Nvidia GPU in 2.92, 2.93 and 3.0. But I'll leave the triaging of this report to others.
backtrace
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(BLI_system_backtrace+0x20) [0xa50dc20]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0xf49fea]
/lib/x86_64-linux-gnu/libc.so.6(+0x3bd60) [0x7fa0fd53fd60]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(GPU_texture_update_sub+0x42) [0x853fac2]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0xf892b4]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0xf8959c]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0xf89904]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0xf89a98]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0x143ca63]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0x143ce46]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0x142da36]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(DRW_draw_render_loop_2d_ex+0x474) [0x142fc04]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender() [0x1cacee2]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(ED_region_do_draw+0x861) [0x188bd21]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(wm_draw_update+0x51e) [0x12dee2e]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(WM_main+0x30) [0x12dcc40]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(main+0x31d) [0xe7786d]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xea) [0x7fa0fd52ad0a]
/mnt/HDD/Home/Alaska/Documents/blender-git/build_linux/bin/blender(_start+0x2a) [0xf4699a]
Python backtrace
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.May 3 2021, 3:42 PM
Can confirm, will check.
Philipp Oeser (lichtwerk) triaged this task as High priority.
Apparently rBb4f0d5247338 is not safe all the way, I am entering GPU_texture_mipmap_mode with a NULL tex
Will step down though, @Brecht Van Lommel (brecht) or @Jeroen Bakker (jbakker) are probably faster fixing this.
Will dare setting this to High prio, it has been around since 2.92, but it is a regression and an operation that is done pretty often I think.
1  blender::gpu::Texture::format_flag_get gpu_texture_private.hh 227  0xddd0c9c
2  GPU_texture_mipmap_mode                gpu_texture.cc         487  0xddd04e0
3  image_get_gpu_texture                  image_gpu.c            419  0x35fbe8e
4  BKE_image_get_gpu_texture              image_gpu.c            441  0x35fbf29
5  space_image_gpu_texture_get            image_engine.c         138  0x3e7ed2a
6  image_gpu_texture_get                  image_engine.c         171  0x3e7ee00
7  image_cache_image                      image_engine.c         190  0x3e7eee4
8  IMAGE_cache_init                       image_engine.c         327  0x3e7f4e5
9  drw_engines_cache_init                 draw_manager.c         1052 0x3e65b7d
10 DRW_draw_render_loop_2d_ex             draw_manager.c         2110 0x3e684d5
11 DRW_draw_view                          draw_manager.c         1520 0x3e66df7
12 image_main_region_draw                 space_image.c          653  0x4c055c7
13 ED_region_do_draw                      area.c                 558  0x45a9235
14 wm_draw_window_offscreen               wm_draw.c              724  0x3b8b194
15 wm_draw_window                         wm_draw.c              864  0x3b8b741
16 wm_draw_update                         wm_draw.c              1065 0x3b8bd79
17 WM_main                                wm.c                   653  0x3b884a3
18 main                                   creator.c              520  0x35983f2
@Philipp Oeser (lichtwerk), I can't reproduce the crash in latest master (rB9f1e20e7).
From the code, it's not clear to me how tex can become NULL in GPU_texture_mipmap_mode?
if (*tex) {
  GPU_texture_wrap_mode(*tex, true, false);
  if (GPU_mipmap_enabled()) {
    GPU_texture_generate_mipmap(*tex);
    if (ima) {
      ima->gpuflag |= IMA_GPU_MIPMAP_COMPLETE;
    GPU_texture_mipmap_mode(*tex, true, true);
  else {
    GPU_texture_mipmap_mode(*tex, false, true);
This is what happens here (this time I had to hammer J quite often, but it can happen with less presses, too):
could this be freed from another thread or so?
I could reproduce now, you're right about the threads.
