Grease pencil. Artefacts at beginning of strokes #87984
Reference: blender/blender#87984
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-04-23 20:25, hash:
17fca62fff
Grease pencil strokes drawn with a stylus have unwanted artefacts at their beginning. Especially noticeable at high radius settings. Related to this, the start of a stroke is often narrower than the artist's intention.
Notes
When you draw with deformable physical natural media (e.g. a paint brush, felt-tip) adding pressure increases the size of the mark, even when the tip is not moving over the paper. Other drawing programs also work this way. Currently blender doesn't work this way.
I looked at the source code (gpencil_paint.c). Here's what i think is going wrong with the grease pencil strokes:
When the pressure difference between two close adjacent vertices is large this can cause ugly 'lumps' in the line.
Currently, stylus pressure can be very different between the first and second vertex recorded in a grease pencil stroke. This is because there can be a large time difference between the recording of the two points; The first vertex stores a record of the pressure only at the moment the stylus first touches the tablet, subsequent changes of pressure before the stylus begins to move across the tablet are not recorded in the stroke. Only after the stylus starts moving is the second point recorded with the current pressure.
Proposed solution
Any time the stationary stylus tip is touching the tablet, the drawing routine polls the changing tablet pressure continuously. When the detected pressure is higher than the pressure of the last recorded point, the pressure of the last recorded point is overwritten by the newly detected (higher) pressure. This way, the pressure of the first and second points in a stroke is much more likely to be similar, the width of the start of the line will more closely match the artists intention, and the likelihood of artefacts is reduced.
Added subscriber: @info-27
Added subscriber: @filedescriptor
@info-27 Are you using Wintab or Windows Ink? Could you try both of them and see if they give different results?
Mentioning #87499 here as this task could be related.
whether using wintab or windows ink i get unwanted artefacts.
(today the artefacts seem less severe, maybe the problem is made worse when cpu is taxed with other processes)
Added subscriber: @PrototypeNM1
I think the analysis in Notes is mostly accurate; this looks more like a grease pencil issue than Wintab/WinInk.
Similar artifacts occur if you keep changing pressure without changing position mid-stroke.
After taking another look at the painting code, I think you guys are right. Working on a potential fix.
So there are two things happening here:
Now the question is, why is it done this way. I hacked together a patch that ignores the two points above (always add a point if the pressure changes).
Here is what this would look like (move the pen, stop, change pressure, move again):
As you can see, that does not look very good. Basically, when we get points that are directly on top/very close to each other, the grease pencil engine does not handle it very well. And I guess that makes sense because a lot of it has to do with the segments between the points. If those have a length of zero then you get problems (as shown in the image).
But I think we can do better. My idea would be: Instead of creating new points when the pressure changes but the position is the same, change the pressure of the current point in the buffer. Or even better, only change it if the pressure got greater. Because otherwise, you could "shrink" the point you are currently drawing on, which doesn't really make much sense painting-wise.
That should in theory solve the issue.
that was exactly my suggestion 🙂
Well... Apparently, I need glasses
Added a patch that implements your idea @bitbutter. From my testing, it works quite well. If you can test the patch for yourself and see if it fixes the problem, that would be great.
