pointiness artifacts when the scale object is small
Closed, DuplicatePublicBUG
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 462.31
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
poitiness node produce artifacts when the scale of the object is too small, (smaller than 10x10x10cm circa), the nodes starts to produce artifacts.
To show the issue, in the attached image I have 2 objects with the same identical topology, the small one has produces the artifacts.
Open the file, press render to reproduce the artifacts.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Tue, May 4, 8:33 PM
I can confirm.
It is interesting to note that the problem only occurs if you apply the scale.
