FBX-Importer Bug. Textures not applied correctly
Needs Information from User, NormalPublic
Operating system: in system-info.txt
this is also in system-info.txt
Worked
Worked Not
the textures are applied strangely or wrong, when using the importer from the new version.
I downloaded an older version and that worked fine.
1.step: Import fbx-model with textures
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Tue, May 4, 3:27 PM
Could you share the .FBX as well?
I will ask if they are OK with it.
Hi @Ruven Taylor (RayFox) , will you be able to share .FBX file? Otherwise, according the tracker policy we can close this issue :)
