graphical error when applying image as texture
Needs Information from User, NormalPublic
Graphics card: Intel(R) HD Graphics 520 Intel 4.5.0 - Build 23.20.16.4973
Broken: version: 2.83.13, branch: master, commit date: 2021-03-09 07:21, hash: rBbb5004673085
I'm trying to learn how to use blender, so i'm playing around with applying an image as a texture to an object, this occurs with every single image i try. i try to apply a texture to the cube, and i get a strange graphical glitch which persists no matter what direction i am looking at the object, and it changes with movement and zoom. the glicth appears as a bunch of white little squares all over the object obscuring the texture partially.
start program, >material properties, white circle to the right side of base color open, clicked folder icon dropdown, selected desired image > change view to material or render preview, glitch occurs in both.
screenshot of glitch here
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Wed, May 5, 3:18 PM
Does upgrading the GPU driver help here?
Please upgrade to the latest driver, see here for more information: https://docs.blender.org/manual/en/dev/troubleshooting/gpu/index.html
https://downloadcenter.intel.com/product/211969/Intel-HD-Graphics-Family
I did check that on th advice a of a friend who has been using blender for some time. there are no available updates for the driver according to Intel, i did discover a small work around. i can apply an image as a texture to objects that i add to the scene without issue so long as the original cube remains somewhere on the scene. I believe the issue is probably on my end, and this simple workaround is consistent and can be repeated to the same effect. I honestly don't know why it does this. but i can manage with just having the starting cube somewhere in the scene out of view
