Sculpt Mode - Expand Active Face Set freeze
Closed, ResolvedPublicBUG
Operating system: Linux-5.4.0-72-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: GeForce RTX 2060/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.73.01
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-04 22:35, hash: rBd08cc63e2f98
Blender freezes after selecting "Expand Active Face Set" from the Sculpt Mode Face Sets menu, if a second mesh was previously added to the object.
Method 1:
With default cube selected, switch to Edit mode.
Add any mesh with Shift A.
Switch to Sculpt mode.
Select Expand Active Face Set from menu or with shortcut.
Method 2:
Duplicate the default cube.
Select both cubes and join them with CTRL J.
  • Freeze is triggered when the active Face set includes all the faces of only one of the meshes.
  • There must be at least 2 meshes in the object for freeze to happen.
  • If part of the mesh has another face set color, the freeze will not be triggered.
  • If both meshes are using the same face set, the freeze will not be triggered.
Thank you!
