Keymap: use D-key for view navigation pie-menu (2nd iteration) #88092
14 Participants
Reference: blender/blender#88092
{F10130612, size=full, alt="View pie menu"}
Motivation
) key isn't always accessible or is not consistent in non US-english keyboards (e.g. Spanish layout has it on the right side next toL
, in some layouts it doesn't even exist)Proposed Solution
Use the
D
key to access the View pie menu.Note: original proposal was to use
V
, but it turns out to be conflicting with too many areas/workflows.Conflicts
D
is one of the most accessible keys on the left side of the keyboard that has been historically (and surprisingly) not assigned (without holding modifier keys) to any crucial tool.D
key in Sculpt mode for theTransfer Mode
operator. This tool is quite handy in a speedy workflow, so the proposal is to change this to the key left to1
, read more in #88071.D
key to switch to the Draw tool, this hotkey needs to be either switched or removed.What about Annotations?
Annotations won't be affected since they are only triggered while holding the
D
key. Whereas the View pie menu is simply triggered on pressOpen Topics
Notes
Task updated by @pablovazquez based on community feedback and a discussion had during a UI meeting on May 20th.
Added subscribers: @ideasman42, @baoyu, @system-system, @jta, @Maged_Afra, @AndresStephens, @finirpar, @AlbertoVelazquez, @Gilberto.R, @1D_Inc, @xan2622, @TheRedWaxPolice, @RedMser, @JulianEisel
Keymap: use V-key for view navigation sub-menuto Keymap: use V-key for view navigation pie-menuHow about using D key?
It's worth considering, this would be much less disruptive.
Added subscriber: @JulienKaspar
@ideasman42 I agree it would be best if we resolve this issue as a bug instead of working around it.
Were there any more results from trying out if the same key position independent of the keyboard layout. Or maybe detecting the keyboard layout settings and adjusting the keymap item based on that?
If all of that fails then I think V could work. But there is a bigger discussion on using the D key right now.
Currently the plan is to map the D key in every mode to the new Transfer Mode operator (#87134).
But there is also still the subject on possibly using a different shortcut for that (#87722) but some conflicts need to be resolved for that.
Depending on the outcome of that discussion the D key could end up being free or not for 3.0.
Added subscriber: @ZedDB
I also think it would be better to not work around the core issue and instead fix it.
I've posted my thoughts in the patch review: https://developer.blender.org/D11189#285826
Added subscriber: @GeorgiaPacific
Added subscriber: @Imaginer
I'd like to mention that this would also conflict with the "Move objects to QCD slots" popup for my Collection Manager addon.
Also, +1 to treating this as a bug and fixing the underlying issue.
Note: added "Open Topics" section, would this apply to other views (not just the 3D view), since there are at least 3 items that could be added to most 2D views.
I think adding a view menu for other editors would probably be a good idea and would keep things consistent. But this seems to be a separate topic unrelated to whether the hotkey is changed?
The ability to quickly and confidently (directly) setting view problem is also known to us.
Even during single reference modeling there is need to observe a model and then quickly return to the referenced view, so it have high relevancy value.
Nums are confident and useful, but requires right hand, widget is not direct, since it works relative to current view, and alt+MMB is not that smooth and confident.
At the moment we solved it in a hard way - bought a G300s mouse for modellers in company with additional M5 button,
set it to front view and modified it with Ctrl/Alt/Shift combinations to get immediate right/left/top/bottom/back views, which - of course - is a sin.
We've got the most confident view direction setting action, but this is not a solution that I can be proud of as a workflow designer.
Technically, we didn't found an appropriate solution, that allow to keep attention during modeling, is fast enough and is compatible with possible defaults.
Keymap: use V-key for view navigation pie-menuto Keymap: use D-key for view navigation pie-menu (2nd iteration)Added subscriber: @pablovazquez
Updated the task description. The main change is to use
D
instead ofV
, as the latter is used much more often in many different workflows.Added subscriber: @ephraimpauli
D11189 has been updated to match changes in this design task.
As far as I know, the
PRESS
event fires before anything else, so I'm pretty sure that means that the view menu would conflict with annotations.Edit: looks like this has been accounted for in D11189 and that it's not just press, it's press + motion. Apologies.
Added subscriber: @Leroy-Xie
@ideasman42 Will the fly mode be changed to {key Shift}+{key d}?
No, this will be left as-is, as it would conflict with duplicate.
Removed subscriber: @Gilberto.R
I'd prefer finding a new place for it - with the
it changes position depending on which computer I'm on, so I end up just not using it. But we could also make it use the physical key location. {key Shift D} is not available of course.Sure. That means that there is some predefined keyboard layout that can be used for specifying defaults, and, this layout at least don't contain tilda (so, for example, we can define that it is not ANSI layout).
That means that tilda can be occupied by default only with non-critical functions.
Is there an agreement how looks such a layout, suitable for defaults design, to avoid guessing?
Maybe keyboard model number, or set of model numbers?
If there is a good alternative I'm fine with using this too, my only concern is that this means there are more trade offs we have to discuss and agree on before going ahead with this patch - since finding good alternative key-bindings that work across all modes in the 3D viewport is not so easy.
While walk/fly navigation are view related, I don't think it's as a hard requirement that moving the view menu key bindings changes this short-cut too.
Note that Ctrl-Tilda is used to toggle gizmos, if we're changing the use of the Tilda the key we could think of changing this too ... but again this gets into the kind of scope creep which can cause patches to be left in an undecided state for long periods of time. So I'd rather avoid that unless the changes are relatively straightforward.
Added subscriber: @NoBlahBlah
So is this supposed to override an existing keymap/userpref.blend cause that's exactly what happened to me. I get that you want to make the keymap more accessible or better etc etc. But you can't just overwrite an existing userpref.blend without the user's permission. How would you like it if git instead of warning you that you have a merge conflict would just reset and then merge stuff into your local branch without your permission?
Unless you customize it key-map, the default key-map will always be used, that includes any changes to the default key-map as Blender is developed.
Added subscriber: @AnsonX10
I use a keyboard without a numpad, and the tilde key has been a perfectly adequate replacement for it.
Specifically, I frequently press tilde and 1 or 3 in quick succession to either switch to my camera view, or to "view selected." Moving the navigation pie menu to D apparently necessitates changing the event type from a "press" to a "click drag" which breaks the workflow of pressing a number key to access the pie menu's features (at least without moving the mouse first, which makes the number key shortcut pointless).
While D is a very convenient key (at least on qwerty keyboards), I'm not convinced it should replace tilde as the view navigation pie key. Particularly when it breaks other features.
I'm in the camp that believes that the key left of the 1 key (or whatever is in that physical location) should call the pie menu on all keyboards, rather than moving it somewhere else. At least for the time being. I'm not opposed to seeking better and more efficient key mappings, but this feels like a step backwards, and a hasty one at that.
Added subscriber: @thinsoldier
How about using the V key? V as in View. It's not used for anything in Object Mode. In Edit Mode on meshes it's used for Rip but I think that alt+v for Rip would be more consistent with the rest of Blender. In Edit Mode on curves it opens a "set handle type" menu that is the same as what's found in the right click menu. Also alt+v is not used for anything when editing curves.
The V-key is used for:
Changing this shortcut is quite disruptive. Further, modifier combinations using V are already used in some contexts too.
We could instead make sure the key to the left of 1 (typically the
key) is always available for view operations.D key can be associated with View Direction.
Speaking of V, as it turned out, V for merge, Alt+V for rip and Shift+V for Join better fits relevance and reduces stress on the wrist by reducing using right side of a keyboard for a relevant modeling actions, since they became accessible from a single wrist position.
