Bug with Curve Doesn't let you enter Edit Mode after undoing back to object mode #88142
Reference: blender/blender#88142
Graphics card: AMD Radeon(TM) Vega 8 Graphics ATI Technologies Inc. 4.5.14757 Core Profile Context 20.12.1 27.20.14501.28009
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash:
02948a2cab
(im bad at explaining) Curves tools stuck in object mode and can't go back to edit mode.
Whenever you are using Curve object and undo it until you are back to object mode you can't enter back to edit mode on that object
but closing the program or re-oping the file it will fix it, same with re-doing one step ahead. its simply don't undo that far to prevent this bug from happening.
[had more time to debug this time.]
Delete Default Cube to see better - move the camera to your liking.
Add a Curve "Bezier" using CRTL A - Select the curve object and enter Edit Mode - Extrude it (place it anywhere) - undo it until you are back to object mode.
enter back to edit mode. (the bug should be in play right in here.).
there isn't a point in sharing my file cause the bug will disappear after re-opening the file.
but here is a video: https://youtu.be/3pw4Zu6kd10
Added subscriber: @andres0rivera
Added subscriber: @Calra
Hey thanks for the report @andres0rivera nice find!
I cannot reproduce on Windows 10 on 2.93 and 3.0.0 here
Also, could you check you have Global Undo enabled in
Edit->Preferences->System
?Also, could you test it on a newer blender version?
Added subscriber: @lichtwerk
similar report : #88172 (Object not following BezierCurve Blender 2.92)
With these reproduction steps, I can actually repro in 2.92.
But 2.93 and 3.0.0 seem to be fine (have not hunted down the exact commit that fixed this).
@andres0rivera : Could you please check a fresh build from https://builder.blender.org/download/ and see if the issue is fixed for you there?
