Asset System: Data Storage, Reading & UI Access #88184
Reference: blender/blender#88184
Internal architecture for storing and accessing assets (actually asset-handles, i.e. an efficient representation of the asset), as well as preparing them for display in the UI.
Current Design
The current Asset Browser design is based on the File Browser. This already has a system for data storage, reading and UI access:
FileList
About
FileList
Each File Browser editor stores a
FileList
. It does a fair bit of heavy lifting. Its main responsibilities are:Main
).There is also a fair amount of code for the old asset engine design.
All of these features are good to have in general, we should not remove them.
Its Problems
FileList
does too many things; there is no separation of concerns.Code is very hard to follow and reason about.
The asset system requires a storage that is independent of the File Browser.
FileList
does UI specific things that are already done elsewhere in the UI.Proposal
We do not need to start entirely from scratch. We should be able to pick apart
FileList
and re-build it into a new design. Here is how that could look.Separation of Concerns
The different responsibilities from above can be split into a few basic concerns:
These are the main concernes that should be separated clearly, with well defined interfaces in-between.
Reading
AbstractFileReader
? TBD.(A bit awkward to call assets "files", besides that it makes sense. Better naming idea welcome.)
TODO. Basically: Recursive, concurrent loading of files from disk (including .blend libraries). Different kinds of files, so OOP style inheritance makes sense.
In future we might want a file-reading implementation for asset caches too. These would be simple .json files with meta-data stored inside an asset library.
Could be exposed to Python somehow, so Add-ons can implement custom asset reading, e.g. via the web.
Storing
Base class
AbstractFileList
.The asset specific implementation would look like this:
// etc.
There could be a separate asset list for each library. That way we can cache that data as we like. Note that we can also lazy-load parts of an asset library into the list.
We'll need some way to identify an asset library (also needed in DNA, so uses C here):
Sybren had the interesting idea of using URIs for this.
There would be a global storage for assets:
/* Global map as storage of asset-lists, per library. */
static AssetListMap global_storage_;
This essentially is a "model" in the model-view-controller pattern.
Viewing
If the storage part represents the model, this part represents the view. Idea is a general abstraction:
uiModelView
. It gives a view into a (potentially big) data-set, i.e. a model. This could be useful for the rest of Blender too, but we can keep it very simple for the start.For assets, there would be the following model-view:
UIs like the
UIList
or the File Browser can get their view onto data via theuiModelView
interface. Once the data is fetched into such a view, they do not need to know about the exact implementation (e.g. if this is an asset list, a file list, an RNA collection, ...).Putting it all Together
Who is responsible for putting this all together?
Few things:
AssetLibraryReference
(could be a URI).AssetListStorage
to fetch the needed assets. For example the asset-view UI template does this before creating the list.AssetList
orAssetListStorage
creates the appropriate reader and invokes it via theAbstractFileReader
interface. The reading can be threaded for non-local data.AssetView
from the readAssetList
. This way it gets a view into the data that it can work with for drawing, interaction, filtering, etc.The File Browser
The File Browser should be ported to using this new design as well. I.e.
FileList
should be entirely replaced by the new design.Workload
All of this sounds like a lot of work. Things can be kept very simple for the start though. We don't need rich APIs yet. This is just about thinking carefully about the general direction, which will have long-term impact. Once we know which direction to go, we can add just the bits necessary for what we need for the current project goals.
Quick update on how the asset system could work together with the file system/list:
Added subscriber: @Michael-Drake
Added subscriber: @AlexeyAdamitsky
I am removing the
label. This is under the general rule that Design and TODO tasks should not have a status.If you believe this task is no longer relevant, feel free to close it.
I don't really want to go this direction anymore, it was from early design exploration, so closing this.
