OSL, Windows, external scripts are not compiled anymore #88323
Closed
opened 2021-05-16 10:55:12 +02:00 by Ilja Razinkov · 19 comments
Operating system: Windows 10
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-05-15 16:29, hash: 610c0ecc3b, type: Release
Worked: 2.91
Recent 2.93 beta always gives cryptic errors when trying to compile any OSL script.
Scripts are perfectly valid, even simple oneliner cant compile with recent build.
To reproduce: try to reload script in attached blend and look into console for this error.
There was similar reports regarding OSL in Windows. And they was closed as resolved for some cases. And they indeed was resolved - beta from May 8 did not has this error, OSL compilation was ok.
But unfortunately the problem raised AGAIN in latest beta, downloaded today, 16 May //
System-info: system-info.txt
Simple Blend: oslScriptFail.blend
OSL to compile: oslScriptFail.osl
**System Information** Operating system: Windows 10 **Blender Version** Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-05-15 16:29, hash: 610c0ecc3b91, type: Release Worked: 2.91 Recent 2.93 beta always gives cryptic errors when trying to compile any OSL script. Scripts are perfectly valid, even simple oneliner cant compile with recent build. To reproduce: try to reload script in attached blend and look into console for this error. ![2021-05-16_11-51-29.png](https://archive.blender.org/developer/F10112327/2021-05-16_11-51-29.png) There was similar reports regarding OSL in Windows. And they was closed as resolved for some cases. And they indeed was resolved - beta from May 8 did not has this error, OSL compilation was ok. But unfortunately the problem raised AGAIN in latest beta, downloaded today, 16 May // System-info: [system-info.txt](https://archive.blender.org/developer/F10112329/system-info.txt) Simple Blend: [oslScriptFail.blend](https://archive.blender.org/developer/F10112330/oslScriptFail.blend) OSL to compile: [oslScriptFail.osl](https://archive.blender.org/developer/F10112331/oslScriptFail.osl)
Author
Added subscriber: @IPv6
Member
Added subscribers: @dr.sybren, @lichtwerk
Member
Compiles fine on Linux.
@dr.sybren: can you reproduce this?
Compiles fine on Linux. @dr.sybren: can you reproduce this?
Added subscriber: @antoniov
Cannot reproduce on Windows.
Cannot reproduce on Windows. ![image.png](https://archive.blender.org/developer/F10123034/image.png)
Member
Since this could not be reproduced (also asked in #blender-coders), will move to the Unconfirmed tag, with following consequences:
The issue reported can't be reproduced so far, and has been moved to the *BF Blender: Unconfirmed* project.
If 2 other people aren't able to redo the bug after 2 weeks, it will be closed.
We appreciate the effort that goes into making bug reports, but to be able to fix bugs we have to be able to redo them.
If there is anything you can provide to help others to reproduce the problem, be sure to include it.
Since this could not be reproduced (also asked in #blender-coders), will move to the Unconfirmed tag, with following consequences: ``` The issue reported can't be reproduced so far, and has been moved to the *BF Blender: Unconfirmed* project. If 2 other people aren't able to redo the bug after 2 weeks, it will be closed. We appreciate the effort that goes into making bug reports, but to be able to fix bugs we have to be able to redo them. If there is anything you can provide to help others to reproduce the problem, be sure to include it. ```
Member
Added subscriber: @LazyDodo
Member
I can't repro with either 3.0 or 2.93 on windows 10
Added subscriber: @brecht
Maybe the underscore at the start of the folder name is related, that's a bit unusual.
Another possibility is that this happens with specific file systems, or some file system configuration related to case sensitivity.
It seems somewhat unlikely to me that this was fixed in Blender and then broke again, since I don't think there were related changes recently. It might have also been something on your system that changed.
Maybe the underscore at the start of the folder name is related, that's a bit unusual. Another possibility is that this happens with specific file systems, or some file system configuration related to case sensitivity. It seems somewhat unlikely to me that this was fixed in Blender and then broke again, since I don't think there were related changes recently. It might have also been something on your system that changed.
It's sort of a bug in OSL that it treats preprocessor warnings as errors, though the warning shouldn't be there in the first place.
Member
This is what we had recently:
#87481 (OSL: Windows: OSL not working, external scripts always give error)
#86928 (Error: OSL script compilation failed)
#87279 (External OSL scripts are not compiled anymore)
and
{rBL62577}
a631a9eb1f
This is what we had recently: #87481 (OSL: Windows: OSL not working, external scripts always give error) #86928 (Error: OSL script compilation failed) #87279 (External OSL scripts are not compiled anymore) and {rBL62577} a631a9eb1f
Author
It is really strange. Just now i started blender 293, loaded file again and... it compiled!!! i swear, i didn`t "make up" screenshots from above, the problem was here 2 days ago.
But, after some investigation i found another case when it is reproducable (on my PC).
I`m developing addons and use "JacquesLucke / blender_vscode" - https://github.com/JacquesLucke/blender_vscode - to run Blender.
And when i start Blender from inside vscode - the error is still here. When blender is started from command line - the error is gone.
Please note, that the screenshot from above was made from clean console run, not from vscode (you can see this on screenshot as well).
So... it seems "JacquesLucke / blender_vscode" addon leave some traces that affect blender sometimes //
Looks like vscode addon start Blender with some overloads (like 'scriptsFolder': 'c:\_WPLabs\Programs\blender293\2.93\scripts', as i see from vscode terminal) and that lead to error in OSL somehow. it is still working perfectly with 2.91 without such OSL problems. Anyway, will contact JacquesLucke then, VSCode is really convenient for writing addons, hope he may help this problem
I totally understand you cant fix unreproducable bugs, and addons behaviour is out of scope. Thanks for your efforts! and i didni expect that vscode addon may affect separate runs of Blender (as it happened in my case), sorry //
It is really strange. Just now i started blender 293, loaded file again and... it compiled!!! i swear, i didn`t "make up" screenshots from above, the problem was here 2 days ago. But, after some investigation i found another case when it is reproducable (on my PC). I`m developing addons and use "JacquesLucke / blender_vscode" - https://github.com/JacquesLucke/blender_vscode - to run Blender. And when i start Blender from inside vscode - the error is still here. When blender is started from command line - the error is gone. Please note, that the screenshot from above was made from clean console run, not from vscode (you can see this on screenshot as well). So... it seems "JacquesLucke / blender_vscode" addon leave some traces that affect blender *sometimes* // Looks like vscode addon start Blender with some overloads (like 'scriptsFolder': 'c:\\_WPLabs\\Programs\\blender293\\2.93\\scripts', as i see from vscode terminal) and that lead to error in OSL somehow. it is still working perfectly with 2.91 without such OSL problems. Anyway, will contact JacquesLucke then, VSCode is really convenient for writing addons, hope he may help this problem I totally understand you can`t fix unreproducable bugs, and addons behaviour is out of scope. Thanks for your efforts! and i didn`i expect that vscode addon may affect separate runs of Blender (as it happened in my case), sorry //
Author
Sorry to bother, but after some more investigation i found the difference that is not involving vscode/addon stuff and is reproducable (on my PC): the way blender starts.
When i double-clicking "blender.exe" - Everything works
When i opening cmd.exe and type "blender.exe" - OSL error occurs
Screenrecord: oslCompBug.avi
Then i saved "system-info" from both ways. They are identical... but with only one exception:
  • in "cmd" mode all paths has a lower "c://": binary path: 'c:\_WPLabs\Programs\Blender293g\blender.exe'
  • in "double click" all paths has an upper "C://": binary path: 'C:\_WPLabs\Programs\Blender293g\blender.exe'
See for yourself: system-info-cmd.txt system-info-direct.txt
Could it be the reason?
UPD: after changing path to blender to be "C://..." in vscode addon preferences it is started to work too... vscode setup was targeting blender with lower case disk char too, as cmd.
So looks like there is indeed something going on about disk char casing... but at least there is a workaround too
Sorry to bother, but after some more investigation i found the difference that is not involving vscode/addon stuff and is reproducable (on my PC): the way blender starts. When i double-clicking "blender.exe" - Everything works When i opening cmd.exe and type "blender.exe" - OSL error occurs Screenrecord: [oslCompBug.avi](https://archive.blender.org/developer/F10124526/oslCompBug.avi) Then i saved "system-info" from both ways. They are identical... but with only one exception: - in "cmd" mode all paths has a lower "c://": binary path: 'c:\\_WPLabs\\Programs\\Blender293g\\blender.exe' - in "double click" all paths has an upper "C://": binary path: 'C:\\_WPLabs\\Programs\\Blender293g\\blender.exe' See for yourself: [system-info-cmd.txt](https://archive.blender.org/developer/F10124531/system-info-cmd.txt) [system-info-direct.txt](https://archive.blender.org/developer/F10124532/system-info-direct.txt) Could it be the reason? UPD: after changing path to blender to be "C://..." in vscode addon preferences it is started to work too... vscode setup was targeting blender with lower case disk char too, as cmd. So looks like there is indeed something going on about disk char casing... but at least there is a workaround too
Member
Member
Member
Sorry this has been lying around.
If I understand correctly, this is an issue with the VSCode Addon only.
@JacquesLucke: Could you have a look (and possibly change the path in the VSCode Addon?).
But since this is not an issue in blender per se, I will have to close this.
Thx again @IPv6 for your investigations!
Sorry this has been lying around. If I understand correctly, this is an issue with the VSCode Addon **only**. @JacquesLucke: Could you have a look (and possibly change the path in the VSCode Addon?). But since this is not an issue in blender per se, I will have to close this. Thx again @IPv6 for your investigations!
Author
No, issue will (should) happen when blender is started from any terminal, not addon only. Casing of characters in path to blender.exe make all internal paths to be cased in one way. While OSL expects them to be always in uppercase. Thus difference->warning->compilation error
(Just to clarify, if someone hit this by google)
But anyway, workaround is quite straightforward, so no problem
>If I understand correctly, this is an issue with the VSCode Addon only. No, issue will (should) happen when blender is started from any terminal, not addon only. Casing of characters in path to blender.exe make all internal paths to be cased in one way. While OSL expects them to be always in uppercase. Thus difference->warning->compilation error (Just to clarify, if someone hit this by google) But anyway, workaround is quite straightforward, so no problem
Member
I am not on Windows, but windows was always case-insensitive in regards to paths, right (remember headaches about this back in the days)?
Assume that since OSL is cross-platform, OSL is case-sensitive and if the "wrong" [lowercase] drive letter is used : will fail.
I am not on Windows, but windows was always case-insensitive in regards to paths, right (remember headaches about this back in the days)? Assume that since OSL is cross-platform, OSL **is** case-sensitive and if the "wrong" [lowercase] drive letter is used : will fail.
5 Participants
Reference: blender/blender#88323
