Operating system: Linux-5.8.0-53-generic-x86_64-with-glibc2.31 64 Bits
Graphics card: AMD RAVEN (DRM 3.38.0, 5.8.0-53-generic, LLVM 11.0.0) X.Org 4.6 (Core Profile) Mesa 20.2.6
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-15 23:00, hash: rB9dabb342ba5e
Undoing using undo history in sculpt rendered mode doesn't work. This doesn't seem to be a problem in workbench i.e in solid and wireframe mode, bug only happens in rendered and material preview mode. In both cycles and evee
- Open default startup file.
2)Go to sculpt mode
3)Switch to rendered mode
4)Make any number of brush strokes
5)Undo to any step after the 'Original' step for example to the 'Sculpt Mode' step.
It is important that the undo history menu is used as opposed to ctrl+Z, even if you undo only one step back with the undo history menu. Also note that if you make any edits in edit mode before entering sculpt mode and making edits there and then undo back to edit mode everything looks the way it should but if you then redo to sculpt mode the same problem appears
