Crash on edit/moving "override frame" keyframes of alembic mesh sequence cache modifier.
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.72
Broken: version: 2.92.0, branch: master, commit date: 2021-02-24 16:25, hash: rB02948a2cab44
Blender crash on edit "override frame" keyframes of alembic mesh sequence cache modifier if object has transforms keyframes.
It happens on 2.83-3.0 versions.
Import abc file
Check Override frame checkbox and set frame range, If you try to move keyframes in dope sheet everything works
Now add transorms to object (move up-down) now if you try to move keyframes (override frame) in dope sheet blender crash
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.May 19 2021, 3:53 PM
Can confirm.
BLI_assert failed: source/blender/io/alembic/intern/abc_reader_object.cc:326, decref(), at 'm_refcount >= 0'
1   raise        0x7ffff77c39d5
2   abort        0x7ffff77ac8a4
3   _BLI_assert_abort        BLI_assert.c              56   0xfe5ce15
4   blender::io::alembic::AbcObjectReader::decref                                   abc_reader_object.cc      326  0x478b694
5   CacheReader_free        alembic_capi.cc           818  0x47175c2
6   BKE_cachefile_reader_free        cachefile.c               206  0x35f8567
7   freeData        MOD_meshsequencecache.c   92   0x4160173
8   BKE_modifier_free_ex                                                             modifier.c                202  0x36abed4
9   BKE_object_free_modifiers        object.c                  1206 0x36dfc89
10  object_free_data        object.c                  280  0x36dcd1a
11  BKE_libblock_free_datablock        lib_id_delete.c           81   0x36661b0
12  blender::deg::deg_free_copy_on_write_datablock        deg_eval_copy_on_write.cc 1081 0xdf58f35
13  blender::deg::deg_update_copy_on_write_datablock        deg_eval_copy_on_write.cc 960  0xdf58bd7
14  blender::deg::deg_evaluate_copy_on_write        deg_eval_copy_on_write.cc 1096 0xdf58fcc
