Grease Pencil: Adding driver in Transform doesn't behave as expected during playback #88433
5 Participants
Reference: blender/blender#88433
Operating system: MacOs 11.3
Graphics card: AMD Radeon Pro 5500M
Broken: Latest 3.0 Alpha
Worked: Never
Adding driver (via "Copy as new Driver and Paste Driver) in Transform (/Layers/Transform) doesn't behave as expected during playback. The viewport doesn't refresh even though the numerical values are clearly changing.
See attached Blend file and screen capture.
Driver.mp4
GreasePencil_DriverProblem.blend
Thanks!
Piotr
Added subscriber: @Pyer
Added subscriber: @antoniov
Hi, this is still an issue. Any ideas on how to fix it? Or maybe a workaround? It's cool (and powerful!) to be able to use drivers with GP... Thanks!!!!
Added subscriber: @lichtwerk
@lichtwerk do you know what module is the right one for this driver bug?
Hello again. I don't know if this helps, but the above steps work as expected on regular objects. So this bug only affects Grease Pencil...
Added subscriber: @mano-wii
Thanks for the report, I can confirm the problem.
Drivers are usually handled by the #animation_rigging module, but the problem can spread to other areas.
Does this really work in Blender 2.93? (I can't find the transform panel to test in this version).
Hi again! It worked on 2.93 (probably alpha or beta, that's when GP Local Transforms first appeared). I did a job back in March and everything worked as expected. But when I load the scene today it no longer does (same Driver problem).
My Blender scene is dated from the 27th of March if that helps you find the 2.93 version of that time (I don't see alpha/beta builds on Blender's archive site).
I don't know where to look in Blender to see precisely what version was used for that scene.
Tell me if you need anything that can help you pinpoint the problem....
(Edited to correct my english)
Ok sorry for the multiple messages. Turns out I was wrong about 2.93 working! I thought I used Drivers on my scene but I wasn't...
So in short, in my experience, Drivers never worked with GP Local transforms.
I'm going to edit my first post to reflect that.
Sorry again for the confusion!
Sorry for asking, but is this going to get fixed?
Hm, weird.
Updates happen coorectly when choosing/changing the layer.
As a first note, here is the
--debug-depsgraph
outputIt works a tiny tad better if the setup is tweaked so we have separate strokes (then the driven at least gets updated):
GreasePencil_DriverProblem_Separate_strokes.blend
Another issue might be that location is never really used directly, but the matrix
gpl->layer_mat
instead.This matrix gets updated correctly via RNA callback
rna_GpencilLayerMatrix_update
(when tweaked through the UI or python), but these callbacks are not executed from the animation systems (so in the end, the matrix might not be up-to-date).Needs more investigation.
Sorry again for asking, but is this going to get fixed at some point?
Thanks,
Piotr
There is an issue when the animation is build twice in the depsgraph for the same ID (the drivers are set up for
Stroke
, but since the driver usesStroke
again, there is something going wrong).I'll try to get to the root of it.
For now though, you can use a workaround:
self
https://docs.blender.org/manual/en/2.93/animation/drivers/drivers_panel.html#expressionsself
in this case is already theGPencilLayer
, so you have to use `self.id_data.layers["Driver"].location[0]GreasePencil_DriverProblem_using_self.blend
This issue was referenced by
333db02e5d
b18122451f
