Technical design for attribute ui list #88460
Reference: blender/blender#88460
Similar to how we have lists for vertex groups, uv maps and more, we would like to have a list of attributes. For pointcloud objects (which are an experimental feature), we actually have the attributes list already. However, for those it was easy, because all attributes (including builtin ones like
position
) are stored the same way. That made it easy to populate a ui list that contains all attributes. Getting the same to work for meshes is more complicated, because mesh attributes are stored in many different ways.I can think of three main ways to get a list of all mesh attributes (including uv layers etc.) in the ui:
UIList
. Here the main difficulty is to create the collection property in rna for very heterogenuous data. More about that later.UIList
itself, so that it can display more arbitrary data that is not stored in an rna collection. This refactor could also be useful for other features, but I can't estimate the feasibility of this change yet.UIList
and draw the list more manually instead. This is surely the simplest and most straight solution. However, it is also ugly and can't match the look and feel ofUIList
.The remainder of this post explores different ways to create an rna collection that can contain all attributes, including builtin (e.g.
position
andmaterial_index
) and special purpose (e.g. uv layers) ones.First, let's have a look at the different ways attributes are stored on meshes. All the attributes mentioned below can be accessed by geometry nodes already.
position
is stored as part ofMVert
.material_index
is stored as part ofMPoly
.shade_smooth
.crease
is stored as part ofMEdge
.normal
is special and I hope that we can remove it as attribute at some point (because it is derived data).The existing attribute api in rna only provides access to generic custom data layers and does not include builtin and special purpose attributes. Below are a few ideas on how the attribute api can be extended to support the different types.
(a) Extend existing attribute iterator with other custom data layer types.
This mainly involves extending the
rna_AttributeGroup_iterator_*
functions.To handle multiple attributes in the same custom data layer (e.g.
material_index
andshade_smooth
in theCD_MPOLY
layer), more information might need to be stored inCollectionPropertyIterator.internal
.Furthermore, new rna types like
RNA_UVAttribute
andRNA_MeshPositionAttribute
might be necessary that handle the data access for builtin and special purpose attributes.(b) Index based iterator.
This is similar to the solution above, but instead of having the iterator reference the attributes directly, it only uses an index. With this we just need to implement a function that counts the number of attributes and one that that gets the correct
PointerRNA
for an index. The main benefit here is thatrna_AttributeGroup_iterator_next
becomes trivial.Unfortunately, this solution might be less efficient under some circumstances, because one has to iterate over all attributes more often.
(c) Attribute handles.
Yet another solution would be to not reference the attribute data directly but to create an indirection.
We could have a
struct AttributeHandle
that contains the name and information about where the attribute is stored. The rna attribute iterator could just iterate over a list ofAttributeHandle
that is stored in theID
. Only when the data in an attribute is actually accessed, aPointerRNA
for the specific data storage is created. This removes the handling of specific data storages from the rna iterator, simplifying it a lot.The main problem with this approach is of course that the attribute handle list needs be kept in sync with the actual set of attributes on the data-block.
Looking at this list now, it seems like (a) is the way to go. There is still the problem with vertex group names though, which are stored on the object...
@HooglyBoogly Guess we should check the feasibility of moving vertex group names to geometry data-blocks soon, before annoying others with this topic :D
I have the same issue with UI-Lists requiring an RNA collection for asset views:
(Note that I've also done quite some refactoring for the UI list code and want to do another pass, so I recommend not changing that for now.)
The assets somehow need to be passed as RNA collection. This case has some further difficulties since we want script authors to be able to place such an asset view anywhere in the UI, so it can't be bound to a specific editor/context.
Doing this would mean scrolling, box size, filter and order settings will not be stored in files. Only few UI types can be stored, UI-List being one of them.
How I did it
What I currently do is require a dummy pointer-property combination for a collection, which can be defined as custom property (reminder, scripts must be able to define own asset views). The items of the collection had to be of type
PropertyGroup
, although that may be just because it had to be usable with custom properties (don't remember the details). So I added anAssetHandle
which could now be put in the collections.Before drawing the list we just always populate the collection from scratch. We could avoid repopulating a lot. Performance would probably be fine in practice, but I hate the unnecessary work.
{https://developer.blender.org/diffusion/B/browse/asset-browser-poselib/source/blender/editors/interface/interface_template_asset_view.cc$160-194}
How I Plan to do it Properly
For me the UI list design ties the model too close to the view. What you have in other widget systems is some kind of model-view as interface to give efficient views into complex data. From #88184 (Asset System: Data Storage, Reading & UI Access):
I think the UI-List would just use an iterator provided by the
uiModelView
.For a timeline, I don't think it will take long to get to this, I got a good chunk of #88184 (Asset System: Data Storage, Reading & UI Access) already implemented.
Nice, thanks for the info. That is quite helpful already!
From what I understand, your current solution is quite similar to my
attribute handles
idea. And you solved the "main problem" that I mentioned in the original post by updating the "handles" explicitly before drawing by callingasset_view_template_refresh_asset_collection
.That can definitely work, would just be a bit annoying if addon developers would have to call some update function before they can access attributes.
Your plan on how to do it properly sounds good to me. I just wasn't sure about the feasibility of a solution like that.
All of that still does not solve the vertex group name issue unfortunately (although it can be worked around more easily if all we want is to display the attributes of an object (instead of geometry)).
Added subscriber: @GeorgiaPacific
Added subscriber: @brecht
@brecht Did you think about this problem when you worked on the initial attribute api? Do you have a preferred solution?
I think (a) and (c) are reasonable. It's useful to be able to access the full list of attributes from Python scripts.
The way I imagined it to work is that the API in
BKE_attribute.h
would be extended to support more types, like UVs and vertex groups. Currently it assumes each attribute to correspond to aCustomDataLayer
, but further abstraction as in (c) can be added. I think that kind of abstraction can also be used by spreadsheet editor or geometry nodes.@brecht thanks, that sounds reasonable. Do you remember why vertex group names are on the object instead of the geometry? Are you aware of any major issues we would run into by moving them to the geometry?
I don't know, that was implemented before Blender became open source. Perhaps it was just copying the shape keys implementation, which I suspect are on the object so you can animate their weights differently for each objects.
Whatever the historical reason, I think it belongs on the geometry. I don't see any major issues moving this. If the mesh and object are in different .blend files, there will be some data loss since you can't version that. But I think that's extremely rare and not a real problem.
