Split Icon SVG File to be 1 Icon per File #88467
9 Participants
Reference: blender/blender#88467
@Shrinks99 did the work of splitting the SVG itself already:
https://devtalk.blender.org/t/splitting-the-icons-svg-file/18937
Next step would be to update the update script ({https://developer.blender.org/diffusion/B/browse/master/release/datafiles/blender_icons_update.py}) to work with the individual SVGs.
Added subscribers: @Shrinks99, @JulianEisel
Added subscriber: @Harley
Added subscriber: @jenkm
Added subscriber: @tiles
Just curious, and while touching this issue, why even stick with svg? The datatoc conversion script converts a png file to dat at the end anyways. So wouldn't it be wiser to work with png in the first place at all? PNG allows to work with gradients and 16 million colors in an easy way. Literally every 2D graphics will work then.
You wouldn't loose anything, you could still create svg icons first in case you really want to. This exports just fine to png. But you could also pixel your graphics in Gimp then. Or render them out. Or paint it in oil, then scan it in. You could use any valid method that produces a bitmap graphics in png format in the end. But at the moment you are limited to a SVG pipeline. And in case of the toolbar icons you are even limited to model your icons first in 3D, to work with a color system that doesn't match, with the cumbersome material setup of Blender, and with a system that does not allow pixel perfect icon creation at all. Pixels is a 2D unit.
So why not go with png for all icons? Then the artist could decide what route he wants to go to achieve his goal.
Added subscriber: @AlexeyAdamitsky
Added subscriber: @jendrzych
Perhaps @jendrzych would be better suited to answer this but I'll give it a go.
SVG is a good choice for authoring icons in general because one can target multiple pixel densities while keeping a resolution agnostic (though technically targeting the lowest resolution) master copy. I find it preferable because I can target the 1x PPI scale, work within the pixel grid, and everything will rasterize predictably at higher resolutions too. An example of this applied within Blender is available in the forum post.
I would also argue that more variation in icon-set production will not lead to a better or more cohesive end product. Sets of icons are defined by their grid, colour scheme, and shape language, I believe by keeping the authoring process standardized as vectors it is easier to keep Blender's icon set consistent. By allowing or encouraging designers to author icons as bitmaps instead of (or in addition to) vectors, I think consistency of shape language would be diminished due to a lack of standardization in the rasterization process.
As for Blender's toolbar icons, I will 100% agree with you there. I also don't think Blender is the right tool for creating these and if anyone wants my opinion it would be "switch to SVG for those too". Nobody asked for my thoughts there though and they look reasonably nice already... However, if there is demand to convert them to SVGs I will happily give that a shot. :)
Thanks for your thoughts Henry,
But this way the artist could decide what pipeline to use. There wouldn't be a need anymore to convince anybody to his favourite method. Since all methods would be allowed. The pipeline would become much simpler and easier and faster. Without the need to have Inkscape installed to be able to change the icons in Blender.
As told, PNG is already part of the pipeline. It's the forelast step. Convert to PNG sheet, then slice this sheet and convert it to dat. And this for both, the regular icons, and the tool shelf icons. And when you would open up the pipeline at this point, then you could still use SVG in the first place, if you want to. Or PNG, Bitmap, etc if you prefer to.
And it would finally be pixel perfect. Since you work with pixels already. Especially the tool shelf icons are not to manage in this regards.
Well, it's in the end your decision. I understand that you at Blender don't want to let the old way go. You are used to the working SVG method, and the whole setup is for this existing pipeline already. I just thought it is a good opportunity to raise my concerns while you are at changes here anyways. From the view of somebody from outside who is not part of the Blender team. Who does custom icons for Blender, and always scratches his head why things have to be this super complicated.
Well, it would already a big improvement to change at least the method for the tool shelf icons. You have my upvote here :)
Kind regards
Tiles
Added subscriber: @RedMser
Added subscriber: @hlorus
There were some historical reasons for this strange SVG > PNG > DAT > PNG pipeline.
After splitting the source file into separate icons, everything becomes easier.
[D13068](https://archive.blender.org/developer/D13068)
.I am not sure that it is reasonable to store the svg source and raster versions in the repository at the same time. There should be one of them.
I prefer bitmap. The source svg can be considered optional and stored outside of the Blender repository, like it does with toolbar icons.
Or you can try rasterizing svg while compiling with, e.g. librsvg, but this needs to be checked for quality.
And actually I have a question what about unused icons or alternative versions.
It would be nice to store them somewhere for future use.
Added subscriber: @IyadAhmed
