Segfault pasting stale driver. #88482
Open
opened 2021-05-22 16:06:55 +02:00 by Will · 6 comments
Operating system: Linux
Graphics card: Intel
Broken: 2.92
Drives copied and pasted with significant change in file data in between can trigger segfaults.
# Blender 2.92.0, Commit date: 2021-02-24 16:25, Hash 02948a2cab44
# backtrace
blender(BLI_system_backtrace+0x34) [0x55dfd70fd084]
blender(+0xe151bd) [0x55dfd4bd41bd]
/usr/lib/libc.so.6(+0x3cf80) [0x7f9b26870f80]
blender(_ZN7blender3deg20DepsgraphNodeBuilder26build_object_data_geometryEP6Objectb+0x170) [0x55dfd7000380]
blender(_ZN7blender3deg20DepsgraphNodeBuilder17build_object_dataEP6Objectb+0x54) [0x55dfd6ffb4b4]
blender(_ZN7blender3deg20DepsgraphNodeBuilder12build_objectEiP6ObjectNS0_26eDepsNode_LinkedState_TypeEb+0x1d3) [0x55dfd6ffe2c3]
blender(_ZN7blender3deg20DepsgraphNodeBuilder22build_driver_variablesEP2IDP6FCurve+0x77) [0x55dfd6ffad87]
blender(_ZN7blender3deg20DepsgraphNodeBuilder14build_animdataEP2ID+0x1f9) [0x55dfd6ffe8b9]
blender(_ZN7blender3deg20DepsgraphNodeBuilder12build_objectEiP6ObjectNS0_26eDepsNode_LinkedState_TypeEb+0x228) [0x55dfd6ffe318]
blender(_ZN7blender3deg20DepsgraphNodeBuilder16build_view_layerEP5SceneP9ViewLayerNS0_26eDepsNode_LinkedState_TypeE+0xb2) [0x55dfd7003892]
blender(_ZN7blender3deg23AbstractBuilderPipeline16build_step_nodesEv+0x76) [0x55dfd6fea296]
blender(_ZN7blender3deg23AbstractBuilderPipeline5buildEv+0x42) [0x55dfd6fea4b2]
blender(DEG_graph_build_from_view_layer+0x33) [0x55dfd6fd24e3]
blender(+0xef501a) [0x55dfd4cb401a]
blender(wm_event_do_depsgraph+0xc5) [0x55dfd4f59245]
blender(wm_event_do_refresh_wm_and_depsgraph+0x92) [0x55dfd4f593b2]
blender(wm_event_do_notifiers+0x36a) [0x55dfd4f6055a]
blender(WM_main+0x2b) [0x55dfd4f5532b]
blender(main+0x367) [0x55dfd4b9da67]
/usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7f9b2685bb25]
blender(_start+0x2e) [0x55dfd4bd056e]
# Python backtrace
  • Add a custom property to the Scene.
  • Right click on its value field, and run "Copy as New Driver".
  • Run CTRL+N or "File" —> "New" —> "General".
  • Right click on any value field, and run "Paste Driver".
**System Information** Operating system: Linux Graphics card: Intel **Blender Version** Broken: 2.92 **Short description of error** Drives copied and pasted with significant change in file data in between can trigger segfaults. ``` # Blender 2.92.0, Commit date: 2021-02-24 16:25, Hash 02948a2cab44 # backtrace blender(BLI_system_backtrace+0x34) [0x55dfd70fd084] blender(+0xe151bd) [0x55dfd4bd41bd] /usr/lib/libc.so.6(+0x3cf80) [0x7f9b26870f80] blender(_ZN7blender3deg20DepsgraphNodeBuilder26build_object_data_geometryEP6Objectb+0x170) [0x55dfd7000380] blender(_ZN7blender3deg20DepsgraphNodeBuilder17build_object_dataEP6Objectb+0x54) [0x55dfd6ffb4b4] blender(_ZN7blender3deg20DepsgraphNodeBuilder12build_objectEiP6ObjectNS0_26eDepsNode_LinkedState_TypeEb+0x1d3) [0x55dfd6ffe2c3] blender(_ZN7blender3deg20DepsgraphNodeBuilder22build_driver_variablesEP2IDP6FCurve+0x77) [0x55dfd6ffad87] blender(_ZN7blender3deg20DepsgraphNodeBuilder14build_animdataEP2ID+0x1f9) [0x55dfd6ffe8b9] blender(_ZN7blender3deg20DepsgraphNodeBuilder12build_objectEiP6ObjectNS0_26eDepsNode_LinkedState_TypeEb+0x228) [0x55dfd6ffe318] blender(_ZN7blender3deg20DepsgraphNodeBuilder16build_view_layerEP5SceneP9ViewLayerNS0_26eDepsNode_LinkedState_TypeE+0xb2) [0x55dfd7003892] blender(_ZN7blender3deg23AbstractBuilderPipeline16build_step_nodesEv+0x76) [0x55dfd6fea296] blender(_ZN7blender3deg23AbstractBuilderPipeline5buildEv+0x42) [0x55dfd6fea4b2] blender(DEG_graph_build_from_view_layer+0x33) [0x55dfd6fd24e3] blender(+0xef501a) [0x55dfd4cb401a] blender(wm_event_do_depsgraph+0xc5) [0x55dfd4f59245] blender(wm_event_do_refresh_wm_and_depsgraph+0x92) [0x55dfd4f593b2] blender(wm_event_do_notifiers+0x36a) [0x55dfd4f6055a] blender(WM_main+0x2b) [0x55dfd4f5532b] blender(main+0x367) [0x55dfd4b9da67] /usr/lib/libc.so.6(__libc_start_main+0xd5) [0x7f9b2685bb25] blender(_start+0x2e) [0x55dfd4bd056e] # Python backtrace ``` **Exact steps for others to reproduce the error** * Add a custom property to the Scene. * Right click on its value field, and run "Copy as New Driver". * Run `CTRL`+`N` or "File" —> "New" —> "General". * Right click on any value field, and run "Paste Driver".
Author
Added subscriber: @WCN
Member
Added subscriber: @lichtwerk
Member
Member
Can confirm.
Can confirm.
Philipp Oeser removed the
label 2023-02-09 14:35:35 +01:00
Philipp Oeser added the
label 2023-02-10 11:09:26 +01:00
Member
Was able to reproduce on latest main (b664de2c8e).
However, initially I had trouble reproducing, and I'm not entirely sure why. (Just noting for anyone who comes along later.)
Was able to reproduce on latest `main` (b664de2c8e0f1cf449c2f32256dd535b3c6d0df9). However, initially I had trouble reproducing, and I'm not entirely sure why. (Just noting for anyone who comes along later.)
Nathan Vegdahl added
and removed
labels 2023-06-06 12:09:01 +02:00
Member
I've tracked down the source of the bug, which turns out to be pretty simple. The issue is as follows:
There is a buffer channeldriver_copypaste_buf in drivers.cc that stores any copied driver for later pasting. However, it doesn't get cleared when the ID block that its driver points at disappears. So any time an ID block gets freed, it can potentially leave a dangling pointer in the driver in channeldriver_copypaste_buf.
In the provided repro steps this is accomplished by creating a new file, which frees the Scene block that the driver points at. But the bug can also be triggered by doing copy as driver on a property of an object, deleting that object, and then pasting the driver.
I'll work on figuring out what the most appropriate fix is.
I've tracked down the source of the bug, which turns out to be pretty simple. The issue is as follows: There is a buffer `channeldriver_copypaste_buf` in `drivers.cc` that stores any copied driver for later pasting. However, it doesn't get cleared when the ID block that its driver points at disappears. So any time an ID block gets freed, it can potentially leave a dangling pointer in the driver in `channeldriver_copypaste_buf`. In the provided repro steps this is accomplished by creating a new file, which frees the Scene block that the driver points at. But the bug can also be triggered by doing `copy as driver` on a property of an object, deleting that object, and then pasting the driver. I'll work on figuring out what the most appropriate fix is.
Reference: blender/blender#88482
