PulseAudio: Audio Files Don't Play in Video Sequencer #88507
7 Participants
Reference: blender/blender#88507
Operating system: Linux-5.4.0-73-generic-x86_64-with-glibc2.28 64 Bits
Graphics card: AMD JUNIPER (DRM 2.50.0 / 5.4.0-73-generic, LLVM 10.0.0) X.Org 3.3 (Core Profile) Mesa 20.0.8
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-05-21 18:43, hash:
d5c3bff6e7
P.S. I downloaded this version:
P.P.S. Is it supposed to say
d5c3bff6e7
, which is the same as the May 22 build?P.S even though this is the same as a previous bug report, that previous report is marked resolved from 9 months ago. But it apparently isn't resolved, at least in the version of Blender I used.
Previous similar bug report:
https://developer.blender.org/T79544
No sound in video sequencer preview.
But both m4a and mp3 works in Blender 2.92 stable.
System Info txt file:
system-info.txt
Added subscriber: @A-Mix-of-Geek-Stuff
Added subscriber: @HDMaster84
Which sound system are you using? Its located at Preferences > System > Sound > Audio Device.
Audio Device was set to PulseAudio (in both May 23 and May 24 builds). I changed it to OpenAL - OpenAL Soft, which is what stable Blender 2.92 was set to, and now sound works for both audio formats (in both builds).
So, I guess set the factory default audio device to OpenAL - OpenAL Soft, please?
Thanks.
You can try updating the pulse audio library, that at least helped here #87584. I Agree that PulseAudio was set a little to quick to default, even though it makes sense as a linux default.
Also see #88089 and #86923. Maybe you can also reproduce the crackling in the audio played by other programs.
Audio Files Don't Play in Video Sequencerto PulseAudio: Audio Files Don't Play in Video SequencerAdded subscriber: @neXyon
@A-Mix-of-Geek-Stuff could you try if this build works with pulseaudio (!) on your system: https://builder.blender.org/download/experimental/blender-3.0.0-alpha+master.a112adf16a06-linux.x86_64-release.tar.xz
Also: which linux distribution are you using?
@neXyon
Hi. It doesn't work right away. I have to change the Audio Device in Blender from PulseAudio to OpenAL - OpenAL Soft.
Here's the Linux I'm using (Zorin OS Lite):
stanley@stanley-MS-7593:~$ uname -a
Linux stanley-MS-7593 5.4.0-77-generic #86~18.04.1-Ubuntu SMP Fri Jun 18 01:23:22 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
stanley@stanley-MS-7593:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Zorin
Description: Zorin OS 15.3
Release: 15
Codename: bionic
P.S. Sorry, I didn't try updating my pulse audio library, and not sure how to do that or where to start.
I haven't heard of this distribution before. Does it even run PulseAudio? Could you try e.g.
pactl list
as command in a terminal and see if it outputs something? If that works, you can also try playing something withpaplay <filename>
where filename should be the path to an audio file (wav or ogg ideally, mp3 doesn't work, at least for me) and check if that works.@neXyon I pasted the pactl list output into the attached text file.
paplay works for both wav or ogg.
pactl list audio from terminal ZorinOS Lite
Here's the website for the OS distribution I'm using:
https://zorinos.com/download/#lite
Note that I'm using the Lite version, which uses XFCE. The main paid version uses a different desktop environment iirc.
Okay, so you have pulseaudio and it works for other applications. Can you start playback in blender and then check if it shows up in pavucontrol (the pulseaudio volume control application, you might have to install it)? For me it looks like this:
Maybe Blender is assigned to the wrong audio device or so?
Added subscriber: @blendsnicely
I have the same problem on Gentoo - no sound from Blender.
It defaults to pulseaudio. I can change that setting as I please, but if it is set to pulse and I then play a video with sound trying to change this setting afterwards will freeze blender (kill -9 ..).
If I first change it to e.g. "OpenAL", then sound will be played as expected.
With both settings Blender shows up in pavucontrol, but with "audio device" set to "pulseaudio" the level meter in pavucontrol is "silence" while playing any video in Blender.
Edit: I am using Blender 2.93.1
@blendsnicely did you try the 3.0.0 alpha daily build, if the problem is still there? https://builder.blender.org/download/daily/
Added subscriber: @Lexx
Added subscriber: @DimitrisChloupis
yes I can confirm the issue happening on Manjaro Linux , no sound, plus that it works well once it changed to openAL, so exact same issue but I am using latest blender 3 and I am on diffirent distro than @blendsnicely
So yes the problem is still active. The only problem is not happening in Blender 3 is the freezing
I assume this bug has been fixed with the recent changes to the PulseAudio backend. Please try to switch back to Pulse from OpenAL and feel free to reopen this bug or open another if you still have issues!
