Mantaflow inflow with shapekeys is not working anymore (regression)
Operating system: Linux-5.11.16-200.fc33.x86_64-x86_64-with-glibc2.32 64 Bits
Graphics card: GeForce GTX 970M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 460.67
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-24 18:46, hash: rB0606a37e1a8c
Broken: 2.83
Worked: 2.82a
Bisecting (good 189e96ba687c / bad 47af235ba987) will result in rB3c74d45c9e90 as the first commit where things go wrong in a way (fluid is not visible after baking), but this might not be the actual breaking commit, rBa5c4a44df67e: Fluid: Bounding boxes for effector objects I suspect more
Mantaflow inflow with shapekeys is not working anymore, flow is happening from the basis shapekey
  • Open blend
  • bake
  • flow is not following the shapekey
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.May 25 2021, 3:47 PM
Philipp Oeser (lichtwerk) triaged this task as High priority.
Philipp Oeser (lichtwerk) created this task.
Will dare setting to High prio since it is a breaking regression
Philipp Oeser (lichtwerk) renamed this task from Mantaflow inflow with shapekeys is not working anymore to Mantaflow inflow with shapekeys is not working anymore (regression).May 25 2021, 3:48 PM
I would say is_static_object needs some work to check for some more stuff before deciding if it's static.
