Attribute Compare Boolean doesn't expose the expected value
Broken: 2.92, 2.93, version: 3.0.0 Alpha, branch: master, commit date: 2021-05-26 10:25, hash: rBafec66c024dc
Worked: -
Boolean type is incomplete for the Attribute Compare node.
  • Add an Attribute Compare node in Geometry Nodes.
  • Set type of B to Boolean
Dalai Felinto (dfelinto) changed the task status from Needs Triage to Confirmed.Wed, May 26, 6:20 PM
Dalai Felinto (dfelinto) created this task.
Possible fix, limit selection of Boolean: P2138
I made some changes to allow boolean in the node, but when I look at it it doesn't really make sense-- the node is meant to compare float values, not booleans. So it's probably better to rely on implicit conversion here.
@Charlie Jolly (charlie) I know it's a trivial change, but do you mind making a patch?
@Hans Goudey (HooglyBoogly) I think you made on already D11427, next time I'll add patch
Yeah, since it's so simple I decided to just move it forward in case you weren't around. Thanks.
