Video Sequencer: Select Linked gives unpredictable results
Graphics card: Intel(R) HD Graphics 620 Intel 4.5.0 - Build 27.20.100.8682
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-02-25 05:34, hash: rB0e1c6a29cbb2
Worked: 2.92
Caused by rB66923031e6f2: Cleanup: Minimize seq->tmp usage
According to the manual, the Select Linked command should " Selects strips, that are placed next to each other without any gaps.". The result of the command however is rather unpredictable.
  • Create a new Video Editing project
  • Add three text strips, next to each other without any gap. I can also be other strip types.
  • Use the command Select Linked; either with the menu or with the shortcut Ctrl+L. If no strips, or the first or last strip are selected, the first and last strip will be selected. If the middle one is selected, it stays selected.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Fri, May 28, 1:24 PM
Philipp Oeser (lichtwerk) triaged this task as High priority.Fri, May 28, 1:42 PM
Will dare setting to High, since it is a regression
After some more testing, I think that also the following Select commands are broken:
  • Select > Grouped : Global Type
  • Select > Grouped : Effect
  • Select > Grouped : Effect linked
Yes they may be broken, but that shouldn't be a regression in 2.93
I would advise to make new report for these, even though I know that they need to be fixed.
This one should be fixed in 3.0
