Undo 3 steps at once in edit mode.
Confirmed, NormalPublic
Broken: 3.0
Undo removes material and slot at the same time and won't redo color change in edit mode.
tab edit mode
add material slot
click (+ new) for a new material
change material color
Now undo, the last 3 steps will be undone at the same time, if you redo after, two will be redone at the same time and the last(color change) can't be redone .
Now try the same thing in Object mode, it works as expected.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.EditedTue, Jun 1, 2:08 PM
Can confirm the issue for 3.0.0, Hash: rBa1556fa05ca9, commit date: 2021-05-31. (Reproducible for 2.92.0 and 2.93.0 also)
(Correct me if correct tag is core here)
