Boolean modifier difference not working properly on plane's with vertex #88727
6 Participants
Reference: blender/blender#88727
Graphics card: GeForce GTX 1650 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash:
5be9ef4177
It similiar like old bug
https://developer.blender.org/T64544
bolean_test.blend
Added subscriber: @ManBlender
Added subscriber: @Calra
Hi, the pictures and blend file are helpful.
Could you also add more steps and observations?
What should have the expected result looked like?
Or what is wrong with the above pictures,
e.g. "Boolean modifier with difference should have done this and this....but this and this happened"
The result of boolean is unpredictable. On image is triangle cuted, but sometimes is other shape, even should be 2 squares and some aditional shape.
On left we se diagonal, but osmetimes is difrent.
I think boolean not coretly interpreting unique vertex, eg. by extrude or added out from standard mesh figures.
Thanks for the information @ManBlender , I am not able to reproduce btw.
Your blender version is bit old can you try again with recent build because this is already fixed with the task #64544.
Do comment here if you can reproduce after upgrading the version. (Will close the task if you fail to comment here in a week)
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-05-19 23:27, hash:
47e88345a1
This same on verisons as upper, the 3th figure is ommited in boolean.
bolean_test2.blend
Added subscriber: @n.luepkes
Hi,
I looked into this and was able to narrow it down a little. As far as I can tell , the problem seems to be related to the direction vertices are ordered in a triangle (clockwise vs counterclockwise). If the ordering of the two operands is different, some output faces are not cut out properly. You can easily reproduce this by setting the scale e.g. in the x-direction of one object to a negative value. This is not only a problem with planes, but also with other (3D) objects.
I'm on master:
7b8d8122774
I found other case where is bug.
84da05a8b8
Doors_example.blend
Added subscriber: @iss
@n.luepkes Unless you plan to fix this bug, don't claim this task and remove yourself as assigned.
@ManBlender I have checked your file bolean_test2.blend and I wasn't able to reproduce problems in 2.93 or 3.0. Are you sure you have uploaded correct file? Are there any special steps to reproduce?
@iss
I checked
bolean_test.blend
now on new version and problem is Little diferent. The cubes are cuted but the rotated post/pole not.Blender Version
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
1b8d33b18c
This same on:
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-07 22:19, hash:
ef5a362a5b
This same on:
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-25 20:57, hash:
5759bbe9f9
@iss
I discoverd that the post/pole it's looks like blender not taken this part to outline. Watch the right side, and compare left - on wireframe exist outline.
Also I made extrude, and not working.
bolean_test_extrude.blend
But when I duplicated the post/pole, the first cuting, second not cuted.
bolean_test_duplicate.blend
Also I made other experiment, I duplicated cuted Cube, and again strange situation. The main cube is not cuted more.
But take point, that in edit mode after select cube by
L
the duplication on cube is like by Extrudebolean_test_duplicate_cube.blend
If duplicated by shift+d in some case the plane disaper from viewport and cube was cuted.
bolean_test_duplicate_cube_.blend
The video is made on:
5be9ef4177
https://recordit.co/xnR0WuJ3Jo
Added subscriber: @howardt
I can check this, there are lot of test cases. @ManBlender just to clarify, please always use latest release to test these problems. Ideally also alpha build from https://builder.blender.org/download/daily/
It will take me some time to get backt to this report so I will CC @howardt
Hi @iss , sorry for the delay. I have uploaded a patch that partially fixes this bug, but I could definitely use some feedback on how to improve it. It would be great if you could have a look at it. https://developer.blender.org/D11726
@n.luepkes sorry for me being impatient, I haven't seen any prior activity on your account, so I fugured this was a mistake as sometimes happens here.
If this is about some operands having negative scale, it is the same issue as discussed in #89391. I am still trying to decide what to do about this. Talking with Campbell this morning, he said that most geometry processing in Blender does not attempt to work properly for things with negative scale. But it does seem there have been past attempts to do so for Boolean in particular.
This is now a confusing bug to follow because there are so many test files. For example, I can't see anything wrong with the Doors_example.blend. If there's something wrong there, please submit a separate bug and explain what is wrong.
For the original bolean_test.blend, I am going to call this working as intended. Boolean is only guaranteed to work if the objects all enclose volumes, and in that example, the third spiky shape has inverted normals so it doesn't enclose a volume.
There were other recent bugs that were similar to this and I fixed them by doing what the Fast modifier does, which is invert the transform matrix if it is negative with respect the main operand's transform matrix. But that doesn't help this case because the Cube object has a mixture of inward facing and outward facing normals.
