Viewport denoising broken after NVIDIA driver update #88831
Closed
opened 2021-06-04 14:51:52 +02:00 by Johnny Varila · 22 comments
Graphics card: NVIDIA GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.63
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: 84da05a8b8
When starting Cycles with viewport denoising enabled and set to automatic Blender hangs and stops responding. Also happened in 2.92 when I tested. Before the driver update viewport denoising worked fine.
Activate viewport rendering in Cycles with denoising set to automatic.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: NVIDIA GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.63 **Blender Version** Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: `84da05a8b8` **Short description of error** When starting Cycles with viewport denoising enabled and set to automatic Blender hangs and stops responding. Also happened in 2.92 when I tested. Before the driver update viewport denoising worked fine. **Exact steps for others to reproduce the error** Activate viewport rendering in Cycles with denoising set to automatic.
Author
Added subscriber: @Zoni
#88862 was marked as duplicate of this issue
Added subscriber: @rboxman
Is there text in the upper left hand corner of the viewport that says "Loading render kernels (may take a few minutes the first time)" ? If so, if you let blender finish that task, do things work correctly?
Author
The task took an unexpectedly long time to finish (over 5 minutes), after that things do work now. However it is not optimal that interrupting the task makes the program crash.
Added subscriber: @deadpin
@Zoni
The current behavior where Optix kernels need to be compiled is expected and will happen just once for each blender/driver version combination. Compilation will start when using Optix for the final render or when using Viewport denoising with the options set to Automatic or Optix.
That said, a "program crash" should not happen. If there is a reliable way to cause this to occur through blender itself, then please either Edit this report to detail that problem or create a new Report and we can close this one out.
@Zoni The current behavior where Optix kernels need to be compiled is expected and will happen just once for each blender/driver version combination. Compilation will start when using Optix for the final render or when using Viewport denoising with the options set to Automatic or Optix. That said, a "program crash" should not happen. If there is a reliable way to cause this to occur through blender itself, then please either Edit this report to detail that problem or create a new Report and we can close this one out.
Author
For me Blender still completely freezes and won't respond after trying to disable viewport denoising after the render kernels have started loading but haven't finished. This happens in automatic and optix modes.
Added subscriber: @kietekas4
same, theres "Loading render kernels (may take a few minutes the first time)" on the top, and it dosent load for me, and when i try to cancel it, whole program crashes
Member
Added subscribers: @merill, @PratikPB2123
Member
Added subscriber: @Blendify
Member
Does this issue still happen with newer drivers or with Blender 3.0 Alpha which can be downloaded from https://builder.blender.org/download/daily/ ?
Added subscriber: @ahmadakil
yes every time until now, but i didn't try it on Blender 3.0
> In #88831#1226884, @Blendify wrote: > Does this issue still happen with newer drivers or with Blender 3.0 Alpha which can be downloaded from https://builder.blender.org/download/daily/ ? yes every time until now, but i didn't try it on Blender 3.0
Contributor
Added subscriber: @Raimund58
Contributor
This comment was removed by @Raimund58
*This comment was removed by @Raimund58*
Contributor
@ahmadakil
Please try with Blender 3.0 and report back.
@ahmadakil Please try with Blender 3.0 and report back. https://builder.blender.org/download/daily/
Added subscriber: @Garek
No activity for more than a week. As per the tracker policy we assume the issue is gone and can be closed. Thanks again for the report. If the problem persists please open a new report with the required information.
Garek closed this issue 2022-01-22 10:10:33 +01:00
10 Participants
Reference: blender/blender#88831
