Choppy audio
Needs Information from User, NormalPublic
2.93 LTS
Ever since I installed 2.93, for some reason the audio is being really choppy even if I set the playback to "Sync to Audio"
At first I thought it was the video itself, but after digging deeper, it turns out its the blender version itself.
Switch to 2.93
add an audio into the video sequencer
switch to "Sync to Audio"
Notice how the audio becomes choppy even in the fastest viewport. Not sure if its just my pc, but this never happened in 2.92
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Sun, Jun 6, 11:35 AM
I am not able to reproduce this with 2.93.0 LTS. If this is happening for a specific file then please attach .blend file with the report.
The issue happens in any file, no point of sending one.
It also seems like I am not the only one with this type of problem by looking at the latest bug reports
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Sun, Jun 6, 12:51 PM
Yes, similar bug reports reported today on tracker. Not sure why I am not able to reproduce this.
Henrik Dick (weasel) changed the task status from Needs Triage to Needs Information from User.Sun, Jun 6, 1:06 PM
@Anoca (Maker26) Please fill in the missing information in your bugreport about your system information. Are you using Linux? Then this might be a duplicate of T88507. Otherwise this one T88875 or this on T88815 could be the same issue, although it's hard to tell just yet. Definitly try if a different sound API like OpenAL fixes the issue.
(image borrowed from T88815 @Philipp Oeser (lichtwerk))
I'm using windows 10 with the latest Intel Core i3-7100
never saw that Sound device option before, lemme try...
Anoca (Maker26) added a comment.EditedSun, Jun 6, 1:35 PM
The audio device was set to Wasapi as default
Changing to OpenAL solves the sound issue for me
EDIT: Correction, SDL fixed it better
What happens, when you try WASAPI with a bigger mixing buffer size? Does it work better then?
tested it and yes, the audio gets better on a higher mixing buffer size while using WASAPI
Great! Seems like our default is too low for your system. What is the lowest value that works fine?
8192 appearently
Guess this is issue is solved then
