Failed to create CUDA context unknown error #88968
Reference: blender/blender#88968
Operating system: Windows 10
Graphics card: RTX 2070 Super
Broken: 2.93.0
Worked: 2.93.0
Changed settings on a project so that my GPU was checked under CUDA. Render times were cut by a factor of 4. No issues on multiple renders. No settings changed, saved project as renamed file. Now it won't render with GPU checked under CUDA at all. Does this regardless of NR settings.
Occurs anytime I try to render with my GPU checked under CUDA.
Drivers are all up to date; this worked perfectly several renders in a row then just stopped working.
I have also rebooted my machine. No change.
Added subscriber: @Rob-Betz
Added subscriber: @ChauHo
I get similar error with Google Colaboratory and Blender 2.93.5:
Error: Failed to create CUDA context (Unknown error)
Invalid value in cuCtxDestroy(cuContext) (device_cuda_impl.cpp:252)
System Information: Google Colaboratory (Linux)
• GPU: Telsa K80
• CPU: Intel Xeon CPU @ 2.30GHz
Blender version
• Blender 2.93.5 (hash
a791bdabd0
built 2021-10-06 06:26:10)Exact steps
• run Blender with command line (use any Blender file):
• values for command line:
/* Source code for GPU2.py */
import bpy
bpy.data.scenes- [x].render.engine = "CYCLES"
Set the device_type
bpy.context.preferences.addons[
].preferences.compute_device_type = "CUDA" # or "OPTIX"
Set the device and feature set
bpy.context.scene.cycles.device = "GPU"
get_devices() to let Blender detects GPU device
bpy.context.preferences.addons["cycles"].preferences.get_devices()
print(bpy.context.preferences.addons["cycles"].preferences.compute_device_type)
for d in bpy.context.preferences.addons["cycles"].preferences.devices:
Added subscriber: @Raimund58
@Rob-Betz Can you please test again with Blender 2.93.5/6 and Blender 3.0 and report back?
Please make sure your GPU drivers are up to date.
@ChauHo Your report is super chaotic. Please try to organise it better so we can understand, what exactly you are doing.
Maybe you can have a look at this script. It might help you to do the things you want.
https://colab.research.google.com/gist/Raimund58/88061f785ea2563d345914d196c15b87/blender_script_for_google_colab_using_the_gpu.ipynb
I use this simple ipynb file
blenderGoogleGPU_2_93_5c.ipynb.txt
and python script for choose gpu
GPU2.py
If remove -p gpu2.py in command line for run Blender in .ipynb file, Blender render use cpu and no error.
This video show how fix this problem (I will try tomorrow, I use all GPU time of today):
How to Fix Google Colab and Blender CUDA Errors - Blender Tutorial
https://www.youtube.com/watch?v=hMCE6-ddTdY
Results:
library fix from video no help, I still have same error
Person create video tell I should not need
in command line run Blender because have
but Blender never use GPU if no have -P 'GPU2.py'. Blend file is from Blender 2.76b and can't set use GPU in Blender 2.76b because my old computer. I upload test .blend file. Don't open it, send it direct to Colaboratory and test there.
MT.blend
Before ≈2 weeks ago, I can use GPU (I use Blender 2.93.5 but need -P 'GPU2.py'). Google change some thing.
@ChauHo Google changed nothing. If you would take a look at my script and maybe run it you will note that everything works fine.
This works fine as well:
-- --cycles-device CUDA
You script work! Ya! But need install many things and still need Python script for set GPU before run Blender. ;)
Google like upgrade and change their sýstem often. Maybe no cause problem for your script. I render several month before problem happen. :) Two days ago Google Drive tell my browser too old and upgrade (can't upgrade because computer and OS too old). Now need use smart phone for upload and download file. :(
Can you not upgrade your OS? Why not? Ever tried Linux?
I use old Macintosh from year 2007. Great machine and use for make MacOS and iOS apps. When get enough money buy I think some thing like System76 Meerkat and use Linux Mint (small and easy move).
Added subscriber: @woojin86
Hi, i'll try to run script, but have error msg:
"Blender 3.0.0 (hash
f1cca30557
built 2021-12-03 00:34:54)Error: Cannot read file '/drive/MT.blend': No such file or directory
Blender quit"
Drive already mounted, and file is present.
What i do wrong?
@woojin86 Your Path is probably wrong.
Please seek support somewhere else. This is a bug tracker for Blender development
