Blender will not start if referencing bpy.context.scene.render.fps with expression in startup file #89046
5 Participants
Reference: blender/blender#89046
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.63
Broken: version: 2.93.0 Beta, branch: master, commit date: 2021-05-19 16:30, hash:
0456223cde
Worked: Unsure if ever worked
Saving the startup file with an expression referencing
disallows Blender to start. If it's not the startup file, the .blend file can be loaded just fine. Tested with the shader editor only, as well as only that attribute. Other drivers or attributes referenced may potentially reproduce the behavior.Exact steps for others to reproduce the error
#frame/bpy.context.scene.render.fps
Blender will start
Extra Notes
After frustratingly trying to figure out what was causing my Blender to crash on startup, I did not test other variables. I would assume that referencing anything in
bpy.context.scene
would cause the issue, but I'm not sure. The#frame
may not be necessary in the example above, but that was my exact input to make the startup fail.blender.crash.txt
BadStartup.blend
Added subscriber: @Toxijuice-3
Thanks for the report.
Not tested yet but is the case same for 2.93.0LTS? Can you check with that? (https://www.blender.org/download/releases/2-93/)
Also if crash reappears in 2.93.0 then make sure to attach crash logs (refer: https://docs.blender.org/manual/en/latest/troubleshooting/crash.html)
Sure thing. Problem also occurs for 2.93.0 LTS.
I've attached crash file as well as a .blend file that should be okay to open normally, but cause the crash if set as startup file.
Also, no crash log for this one, but I can confirm that this occurs on the 3.0.0 Alpha, cycles-x branch, hash: 94caae981738
blender.crash.txt
BadStartup.blend
Added subscriber: @lichtwerk
Can confirm.
also getting:
This issue was referenced by
497bc4d199
