Snap Utilities Line Addon Doesn't Work in 2.93.0 #89062
Closed
opened 2021-06-11 17:55:52 +02:00 by Min · 7 comments
Operating system: Windows 10 Pro 64 bit
Graphics card: EVGA RTX 2060 Ultra KO, NVIDIA 462.59 driver
Broken: 2.93.0, 84da05a8b806, master, 2021-06-02 11:21
Worked: 2.92.0
The Make Line tool from the Snap Utilities Line addon does not snap to any vertex or edge on mouseover like it did in previous versions. Other functions like perpendicular/midpoint edge snapping do not work either. This often results in floating vertices on a mesh instead of proper cuts.
Use the Make Line tool on any mesh and compare the lack of edge snapping to previous versions of Blender.
**System Information** Operating system: Windows 10 Pro 64 bit Graphics card: EVGA RTX 2060 Ultra KO, NVIDIA 462.59 driver **Blender Version** Broken: 2.93.0, 84da05a8b806, master, 2021-06-02 11:21 Worked: 2.92.0 **Short description of error** The Make Line tool from the Snap Utilities Line addon does not snap to any vertex or edge on mouseover like it did in previous versions. Other functions like perpendicular/midpoint edge snapping do not work either. This often results in floating vertices on a mesh instead of proper cuts. **Exact steps for others to reproduce the error** Use the Make Line tool on any mesh and compare the lack of edge snapping to previous versions of Blender.
Author
Added subscriber: @Nominous
Member
Member
Member
Thanks for the report. Reported issue is possibly fixed with the commit f418b29387
@Nominous , can you please try again with fresh builds? (https://builder.blender.org/download/daily)
Thanks for the report. Reported issue is possibly fixed with the commit f418b29387 @Nominous , can you please try again with fresh builds? (https://builder.blender.org/download/daily)
Author
@PratikPB2123 Thank you, I can confirm that it works correctly again in the alpha (blender-3.0.0-alpha+master.fafd21b14c23-windows.amd64-release.zip). :)
Member
Changed status from 'Needs User Info' to: 'Resolved'
Germano Cavalcante was assigned by Pratik Borhade 2021-07-23 13:50:10 +02:00
Member
Thank you for checking. Germano also added the commit in 2.93 LTS maintenance task (blender/blender#88449) so I think its safe to close the ticket.
Thanks again for the report :)
>Thank you, I can confirm that it works correctly again in the alpha Thank you for checking. Germano also added the commit in 2.93 LTS maintenance task (blender/blender#88449) so I think its safe to close the ticket. Thanks again for the report :)
2 Participants
Reference: blender/blender-addons#89062
