Search not working in geometry nodes add node menu #89072
2 Participants
Reference: blender/blender#89072
Graphics card: NVIDIA GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-10 23:01, hash:
461ba4438f
When searching the add node menu in geometry nodes, the list is empty. Nodes can still be added through the default menu, but the search option is broken.
Add a geometry nodes modifier to a mesh. In the geometry nodes editor, press SHIFT+A>Search. No nodes are available from here.
Added subscriber: @Zorro_weaver
Search not working in geometry nodes add node menu.to Search not working in geometry nodes add node menuAdded subscriber: @PratikPB2123
Can you check again with fresh build? (https://builder.blender.org/download/daily/)
Issue you are facing is may be similar to: #89001 (Blender 3.0 alpha : At some point Search in shader editor stops working)
I tried again with today's build. Sometimes, it works. But then all of the sudden, it stops working, and stays that way for a while.
It looks like the exact same symptoms as #89001 to me.
Can you check again with default settings (
File -> Defaults -> Load Factory Settings
)Interesting. I did what you suggested, and it worked fine with the default settings. I enabled my addons one by one to see if it could be one of my addons causing an interference of some type. It turns out, as soon as I enabled Erindale Toolkit , my search stopped working. The current version is made for 2.93, so it makes sense that I had some problems when trying to use it in an experimental 3.0 . I will make sure to check my addons next time I report a bug.
Changed status from 'Needs User Info' to: 'Resolved'
Ok then, Closing the task.
Thanks again for the report! :)
