Line art modifier clips with object on (MBP 16")
Confirmed, NormalPublic
Operating system: macOS Big Sur
Graphics card: 5500M
Broken: 2.93.0 LTS
Worked: -
Line art modifier (grease pencil) seems to clip into / z-fighting the object.
Just add a new line art modifier, possibly a mac problem?
Test File:
Changing the object material to transparent helps a bit.
Setting Line Art modifier -> Chaining -> Angle Splitting to 180 seems to fix the lines, but still a lot of clipping if 3d-object material has any opacity.
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Needs Information from User.Jun 21 2021, 2:51 PM
Can you attach a simple .blend file? I can not reproduce this from scratch
Here's a sample file.
Seems that similar glitch appears on pc, so not sure if its by design? I would expect there is some way to draw grease lines "always on top" of objects.
Pratik Borhade (PratikPB2123) changed the task status from Needs Information from User to Needs Triage.Jun 22 2021, 11:17 AM
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Jun 23 2021, 4:56 PM
