`.draw()` method allows arbitrary scene changes after calling `.template_list()` with custom list type.
Confirmed, NormalPublicBUG
Operating system: Linux
Graphics card: Intel
Broken: 2.92, 2.93.0
Usually Blender forbids property changes in .draw() methods. But they're not caught after a call to .template_list() with a custom list type.
This allows some weird and fragile behaviours to be implemented, both on purpose and accidentally. For example, the below panel has a draw method that increments its list's index on every redraw:
Code examples:
def draw(self, context):
	context.scene.SomeProp = 5
Fails: AttributeError: Writing to ID classes in this context is not allowed: Scene, Scene datablock, error setting Scene.SomeProp
	self.layout.template_list(*someargs)
	self.layout.template_list(listtype_name="ACustomList", *someargs)
Works, but probably isn't meant to.
Download the attached .BLEND file, then mouse over the open "Draw Method Abuse" panel in the 3DView to trigger its draw method.
The displayed EnumProperty can be set to "Fail" to exhibit the usual behaviour, or "Abuse" to show the anomalous behaviour.
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Jun 18 2021, 8:10 PM
I can confirm.
This is because bpy_class_call is being called like recursively and so rna_disallow_writes is reset ahead of time.
This could fix:
diff --git a/source/blender/python/intern/bpy_rna.c b/source/blender/python/intern/bpy_rna.c
index fb1cb823964..89515e409e1 100644
--- a/source/blender/python/intern/bpy_rna.c
+++ b/source/blender/python/intern/bpy_rna.c
@@ -8557,6 +8557,7 @@ static int bpy_class_call(bContext *C, PointerRNA *ptr, FunctionRNA *func, Param
 #ifdef USE_PEDANTIC_WRITE
+      const int prev_write = rna_disallow_writes;
       rna_disallow_writes = is_readonly ? true : false;
 #endif
       /* *** Main Caller *** */
@@ -8566,7 +8567,7 @@ static int bpy_class_call(bContext *C, PointerRNA *ptr, FunctionRNA *func, Param
       /* *** Done Calling *** */
-      rna_disallow_writes = false;
+      rna_disallow_writes = prev_write;
 #endif
       RNA_parameter_list_end(&iter);
This seems to be something for the Python API team.
