Eevee instant crash with a custom node from template example #89260
6 Participants
Reference: blender/blender#89260
Graphics card: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash:
84da05a8b8
Caused by
e125305af4
Instant Blender crash when custom node template have defined some node with a enumerator property, and this property is named 'default_value'.
Not any problem if the property have different name, i.e. 'my_enum_prop' in the original template
eevee_crash.blend
I added an small video to explain. Sorry for my bad english!
eevee_crash.mp4
The blender_crash.txt generated..
blender.crash.txt
Added subscriber: @povmaniac
Eevee instant crash whit a custom node from template exampleto Eevee instant crash with a custom node from template exampleAdded subscriber: @Jeroen-Bakker
Issue seems to be that the node compiler handles custom sockets as floats. float sockets has a default_value attribute but is stored in a different way, hence an error occurs.
Issue seems that the socket isn't marked with SOCK_CUSTOM.
Regression: Working fine with commit on master
de06cb8559
. Will bisect to find the culprit shortly :)Here is the first bad commit:
e125305af4
Looks like I was wrong up here, maybe I checked that with Cycles render engine :p
Added subscriber: @ideasman42
The error is that an enum property is being accessed as a float which shouldn't be happening.
e125305af41a7360c52b9a38024b7e24fde06d70
changed the layout ofEnumPropertyRNA
so the error was hidden before this (although it would assert in debug builds).Support for enum sockets needs to be added or at the very least - skip them to avoid crashing.
Added subscriber: @Raimund58
I can't understand this..
The code that I use in the attached scene is from the template examples included into Blender.
Can you explain in what part of the attached example code the enumproperty is accessed as a float ??
Best regards..
Pedro.
I can't understand this.. where is it supposed to be marked as SOCK_CUSTOM, in the addon part or in the core of Blender?
Thanks for any explanation.
Cheers..
I have investigate a bit this problem. There are the result:
A simple custom node with a enum property, called 'default_value' is enough to cause a crash, even if these node are disconnected from any node tree.
So the main question: why Eevee try to process a node, even not linked in the node tree, and created from other render engine???
The 'normal' behaviour, at least from all my addons is:
Never, in any case, a isolated node is processed, except if is a output node type. And for more safety operation, each engine only search for they own output node types
I think Cycles does the same behavior, but why Eevee not?
The above defined policy allow create a multiple node trees into the editor, one for each engine, without issues.
Each engine only read your own nodes.
@ideasman42 @Jeroen-Bakker what do you think, guys? Any other clue are welcome.
This issue was referenced by
419b4e0b00
a5c59fb90e
