Crashing during animation with Geometry Nodes ( when clicked on Attribute Randomize - Attribute field ) #89313
7 Participants
Reference: blender/blender#89313
Broken: version: 2.93, 3.0.0 Alpha, branch: master, commit date: 2021-06-18 21:33, hash:
f9aea19d98
Crashing during animation when using Geometry Nodes - when clicked on Attribute Randomize - Attribute field
Open the file, start animation and click on the attribute search button:
scale.blend
OR:
Creating simple scene with an animation of rotating brush :
Added subscriber: @PetrSmrtka
Thanks for the report. Can you please provide a simple .blend file?
Added subscriber: @dfelinto
I can reproduce this with 2.93 and master. It crashes as soon as I go in the attribute search.
scale.blend
For the records this is the bracktrace (for the main thread): P2191
Added subscribers: @JulianEisel, @HooglyBoogly
Interesting. It's use-after-free of the attribute hints. I think this is the cause:
The most straightforward solution is probably to disable attribute search when animation is playing, but this must be a relatively common problem in the UI.
@JulianEisel, is disabling the search generally the right approach?
I don't think it makes sense to disable attribute search. Although it seems harmless to do so now, it will be a problem when we have the physics clock detached from the animation clock.
Can't there just be a level of indirection, so the evaluated geometry set pointer isn't used directly? E.g. either the button gets a pointer to the pointer (so the latter can change without issues) or it gets the pointer to the owner (or the owning ID even) of the geometry set.
Just wanted to mention that tooltips are disabled as well when the animation is playing, not sure if the reasons are similar.
Given the conversation above I don't know the best solution. Now that the node UI storage is stored on the modifier, at least attribute search works now, but it still crashes when you apply an attribute, because the underlying problem is the same--
AttributeSearchData
has a pointer to an old node tree because the the UI isn't redrawn during animation.Not quite true. The pointer to the tree is fine (it's original dna data), the pointer to the
GeometryAttributeInfo
is outdated after the modifier ran again.Here is an alternative solution that does not quite work yet, but could work if we do a refactor in the ui code: P2277.
The idea is, instead of referencing
, we just copy it into the "state" of the search uibut. This way we can't get a dangling pointer.The reason this does not work yet, is because the free function passed to
UI_but_func_search_set
does not work as intended yet. We should just get rid of all thoseargN
stuff, and just always havearg
andarg_free
. This would give us much more flexibility with what we can put into auiBut
. Not sure how much of a refactor that would be.I think some of what Jacques is mentioning might make sense, and issue is still really ugly from a code architecture perspective, since this node isn't exposed anymore I don't think this needs high priority.
Well, after testing, this problem still applies in the modifier.
Still wondering why this is not an option. A pointer to the pointer should be fine if it's only the pointed to memory that is recreated.
I suppose that would work if the original ID was not reallocated during animation playback. I assumed that wouldn't be true, but maybe it is? I can look into it.
Assigning to Hans since he said he will look into it.
Don't think the original ID would be recreated then. But it may be on undo (esp. if the undone change was to the ID in question).
Okay, maybe that will work then. We'll see if undo is still an issue.
I looked into this yesterday, ended up getting frustrated battling some warnings:
I'll look into it again tomorrow.
This issue was referenced by
22ffd69a91
