Weird glitch at some models
Confirmed, NormalPublic
Graphics card: AMD Radeon(TM) Vega 8 Graphics ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10.44.05 27.20.11044.5003
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
When importing collada(dae) models, some weird glitch shows up (this might also happen with the other models).
  • Open Blender
  • File -> Import -> Collada (Default) (.dae)
  • Import a file (I used Silver the Hedgedog)
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Jun 21 2021, 9:46 AM
Has this worked in a previous release? https://download.blender.org/release/
(unable to reproduce here with a 970m in Linux)
Also, please try updating your driver. Your’s is from November 2020 it appears.
Can reproduce on windows but I will double check after upgrading the driver
(I think it's a driver specific issue)
Graphics card: AMD Radeon(TM) 535 ATI Technologies Inc. 4.5.14831 Core Profile Context 21.5.2 27.20.21003.8013
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Thu, Jul 15, 3:57 PM
Tim Smith (tims) added a comment.EditedWed, Jul 28, 12:22 PM
Can confirm this issue. In my experience, the artifacts appear with multiple material slots when one of the materials has <1 viewport display color alpha. Minimal steps to reproduce the issue:
  1. Create a new default scene (File->New->General)
  2. Confirm you are using solid shading and your color is set to "Material" in viewport shading settings
  3. Adjust the cube's default material viewport color alpha. Observe no artifacts.
  4. Add a material slot to the default cube.
  5. Adjust the cube's default material viewport color alpha. Artifacts appear when the viewport color alpha is less than one.
Tested on two separate Windows 10 machines with AMD GPUs, artifacts appear on both machines. Both machines have updated drivers as the time of writing this message. No artifacts on a machine with Intel GPU.
The artifacts do not appear in v2.90.1 or anything earlier, but start to appear after v2.91.0. I compiled multiple versions between v2.90.1 and v2.91.0, and the artifacts begin to appear after rB854c999d827c.
