Location unknown bug #89333
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#89333
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
Added subscriber: @KarmazJusitoz
When I import or export the file as obj or fbx the system will said as error unkown location or error blender/blender#80955 can you help me ?
Added subscriber: @chemicalcrux
The popup says "unknown location" because it can't figure out which file it was in when it had an error. The actual problem will be shown somewhere else in that popup.
Can you attach the .blend file that you're working on? We can't do anything without an example.
Added subscriber: @rjg
@KarmazJusitoz Currently your bug report is empty. Please either edit it or create a new bug report through Help > Report a Bug in Blender. We need all bug reports to follow the submission template . Please provide system information (operating system, GPU, graphics driver version), affected Blender version, previous Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
