GPencil: Multiple lattices reduces FPS #89349
Reference: blender/blender#89349
Operating system:Windows 10
Graphics card:RTX6000
CPU:intel xeon platinum 8179m
Broken: 2.93
When version 2.93 is updated, you can add multiple lattices to the same Greasepencil, you have a new one problem
Adding multiple lattices to the same Greasepencil reduces the frame rate to 3 fps
CPU utilization is very poor,mainly focused on the use of a single
Step to Reproduce the error
G
Test File:
#89349.blend
Short video:
Added subscriber: @RayLee
Adding multiple lattice modifier drops the FPS almost to 6-12.
Confirming the report but
Grease pencil
module team can answer this in better way.System Information
Added subscriber: @antoniov
@RayLee Could you provide a simple test file to profile where is the bottleneck?
【Greasepencil】Multiple lattices cause Cottonwoodto GPencil: Multiple lattices reduces FPSChanged status from 'Confirmed' to: 'Needs User Info'
Hi @antoniov , initially I confirmed the ticket, now unsure if there is actual fall in FPS.
Tried with default 2d animation scene.
From my observation: FPS increased when adding Lattice modifier in stack but FPS reduces when I stopped to add them (I think its obvious)
@PratikPB2123 the point in your comment is
From my observation
... I have tested in my PC and I don't see anything, so maybe my example is not the best or I'm doing something different, this is the reason I would like to have a test file.You can understand that for us is a time consuming task to prepare a test file for each bug report, so if you provide a test file we can go to the problem itself, instead to try to reproduce it first creating a test file.
Thanks for your understanding.
@antoniov , sorry to keep you on wait. Attaching the file. (Also updating the task description)
Yes, I understand.
#89349.blend
Thanks @PratikPB2123 for the file. I will do a profile test to see what is going on.
In the first test with your file, I don't see anything below 21 FPS (only in one frame) and later keeps 25 FPS all the time. I have a i9-9900K CPU with NVIDIA RTX2080 TI using Windows 10.
Could you record a small video with the exact steps you do?...maybe you do something in a different way than me and this is the reason.
Also, have you tested in a different PC with different hardware setup?
About threading, the modifiers evaluation is done in a single thread because need to do sequential, so don't see a way to make it multithread.
Second test with your file. I'm able to get sustained 40 FPS
Uploaded the video
Not yet. I will check with other laptop on weekend
Looking at your video I see why I could not reproduce, we were looking at different things. The modifiers are optimized to keep fast FPS playing animation.
In you video you are editing the data and you are looking at the FPS of the viewport refresh. In this case, the system precalculate a lot of things every time you edit a point. This is done to get fast play, but the cost is the edition is slower.
Every time you edit the stroke, the internal geometry of several things of the stroke is calculated and saved to use later and this is what you get. Also, this is not related to modifiers only, modifiers just add more complexity to the calculation.
I have tested in my system and I don't notice any lag editting the lattice, but I did not made a measure with a tool. Of course edit with lattice modifiers is slower, but this is normal and don't make edit unusable.
I don't know what we can do here to improve speed because the problem is if we delay updates in edit, the play speed will be worst.
@antoniov I’m sorry I didn’t get the message until now. Here’s an interesting question: 1. When I have a character that has 10 lattices, FPS is very low.
Also, I don’t know if you’ve noticed, but the CPU only uses a single thread, and the utilization is very low.
Check out the video for details
https://youtu.be/RmgKGsnJlXA
Added subscriber: @lichtwerk
Changed status from 'Needs Triage' to: 'Needs Developer To Reproduce'
Thx for the report!
Reading all this makes me think this is more of a request for performance improvement than a real bug.
Even if we run into a suboptimal, non-linear scaling of performance with multiple lattices or seeing the fact that multithreading is not utilized well, the tracker would still be the wrong place to handle this I think.
Unless there is something obviously wrong @antoniov? Usually this would be closed due to the following policy (but will let @antoniov decide):
Changed status from 'Needs Developer To Reproduce' to: 'Archived'
We can close it because this is a feature request..not a bug.
