Boolean is not working properly with exact faces as 2.92 #89391
6 Participants
Reference: blender/blender#89391
Graphics card: NVIDIA GeForce RTX 3090/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 466.27
Broken: version: 2.93.1, branch: master, commit date: 2021-06-22 05:57, hash:
1b8d33b18c
Worked: 2.92
I had a file that has a wall with multiple Booleans and it was working very well in the previous version , now it is almost not working , I guess it is a bug related to hole tolerant feature as this wasn't available before
Just opening an file created with 2.92 , Boolean operation doesn't work as intended
Notch.blend
Notch.blend
Added subscriber: @Basarchitects
#90987 was marked as duplicate of this issue
#90035 was marked as duplicate of this issue
Added subscriber: @chemicalcrux
This may be a duplicate of #89330.
Added subscribers: @howardt, @iss
@howardt can you check?
It was not fixed by the fix for #89330. I will look into this one now.
The problem is that the object G_562044 in this file has negative scale factors (on all three axes).
It happens that the object Cube.007 also has all negative scale factors, and therefore the boolean with that object works as the user expects.
However, the object Cube.093 does not have negative scale factors. So when everything is transformed into the local space of G_562044, the boolean with Cube.093 ends up with the normals reversed from what the user intends.
Boolean pays attention to what direction the normals are in to determine "inside" vs "outside" of objects. I think 2.92 may have worked because a different triangulation method was used and it may have not respected the negative scale to reverse normals. It should not have worked, in my opinion.
So I am calling the code working as intended here.
In the sample file, if you apply all transforms to all objects, and then flip the normals of the objects that reversed after doing that (G_56044 and Cube.007) then you get the expected result, I believe.
Added subscriber: @Foaly
@howardt
I disagree. The old behavior was both consistent and useful:
Changed status from 'Resolved' to: 'Confirmed'
Looking through the code, handling negative scale is intended to work.
See for example the checks for
is_negative_m4(object->obmat)
inMOD_boolean.cc
.Raising to high, since this is a recent regression.
Added subscribers: @OwlHuman, @PratikPB2123
This issue was referenced by
0aad8100ae
I will note that while I say this is fixed now, it only works if you check the "hole tolerant" option on Exact.
Thank you for your effort , but I have a questions maybe sounds a bit dumb , why the checkmark is red 🤔?
Just a fault sorry 😞
Re-assigned
Added subscriber: @restlesscavy
