Only one instance shown if object being instanced consists only of verts and edges
Confirmed, NormalPublic
Graphics card: GeForce GTX 970/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version: 3.0.0 Alpha, branch: master, commit date: 2021-06-20 22:39, hash: rB6afafc46f639
  • open
  • see that there's just one instance in the bottom left corner
  • unmute Point Distribute node -> result's the same(one instance)
  • select Cube object and switch to Edit mode -> instances look correct
  • from the spreadsheet editor it's clear that instances were created
Funnily enough there seems to be a similar issue with particle system https://developer.blender.org/T84710
Miro Horváth (dreamak) renamed this task from Only one instance placed if object being instanced consists of only vertices to Only one instance shown if object being instanced consists only of vertices.Jun 24 2021, 8:27 PM
Miro Horváth (dreamak) updated the task description. (Show Details)
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Jun 25 2021, 3:51 AM
I can confirm with present instance object (Cube) but could not replicate the issue from scratch.
Confirming for now.
Found that the problem is only replicable when instance object has all isolated vertices.
Also, if I add any node from the Attribute category after the Point Instance node, all instances appear again.
Similar issue with mesh that consists only of edges(no faces) here https://developer.blender.org/T89728
Pratik Borhade (PratikPB2123) renamed this task from Only one instance shown if object being instanced consists only of vertices to Only one instance shown if object being instanced consists only of verts and edges.Thu, Jul 8, 1:06 PM
