Enabling Blenderkit close blender after 10 sec #89528
Closed
opened 2021-06-29 14:47:40 +02:00 by Quentin Theret · 8 comments
Graphics card: Intel(R) HD Graphics 520 Intel 4.5.0 - Build 26.20.100.8142
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: blender/blender@84da05a8b8
Addon Information
Name: BlenderKit Online Asset Library (2, 93, 0)
Author: Vilem Duha, Petr Dlouhy
Blender close without a warning after enabling the addon.
When i enable the addon Blenderkit, 10 to 15 sec later blender close without a warning. Its happening on any file and i tried on the blender portable version and its also happening.
**System Information** Operating system: Windows-10-10.0.19041-SP0 64 Bits Graphics card: Intel(R) HD Graphics 520 Intel 4.5.0 - Build 26.20.100.8142 **Blender Version** Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: `blender/blender@84da05a8b8` Worked: (newest version of Blender that worked as expected) **Addon Information** Name: BlenderKit Online Asset Library (2, 93, 0) Author: Vilem Duha, Petr Dlouhy **Short description of error** [Please fill out a short description of the error here] Blender close without a warning after enabling the addon. **Exact steps for others to reproduce the error** [Please describe the exact steps needed to reproduce the issue] [Based on the default startup or an attached .blend file (as simple as possible)] When i enable the addon Blenderkit, 10 to 15 sec later blender close without a warning. Its happening on any file and i tried on the blender portable version and its also happening.
Author
Added subscriber: @Quentin.theret
Member
Member
Not sure but could be same as described here #88901 (BlenderKit crashes Blender startup if no active internet connection available)
Make sure to have stable internet connection.
With Present information I am unable to help you much since I can not reproduce the crash.
Not sure but could be same as described here #88901 (BlenderKit crashes Blender startup if no active internet connection available) Make sure to have stable internet connection. With Present information I am unable to help you much since I can not reproduce the crash.
Author
Hello Pratik, well blender as no problem until i activate the addon, some of my colleagues think it can be the lack of my pc's power because they don't have any problem with the addon.
Author
Well nervermind, i tried again the technic used in the ticket you gave me and this time it worked, don't really know what i did wrong the first time but seems like its all working fine now. At least for now it didn't crashed.
Member
@Quentin.theret , then please confirm if your device is above minimum requirements: https://www.blender.org/download/requirements/
>think it can be the lack of my pc's power @Quentin.theret , then please confirm if your device is above minimum requirements: https://www.blender.org/download/requirements/
Member
Good to hear it works. I will close the report for now if crash is not appearing now. But feel free to reopen the ticket or submit a new if problem reappears :)
>seems like its all working fine now. At least for now it didn't crashed. Good to hear it works. I will close the report for now if crash is not appearing now. But feel free to reopen the ticket or submit a new if problem reappears :)
Member
2 Participants
Reference: blender/blender-addons#89528
