The tools panel suddenly disappears in engraving mode.
Confirmed, NormalPublic
Graphics card: Quadro K620/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 425.31
Broken: version: 2.93.0, branch: master, commit date: 2021-06-02 11:21, hash: rB84da05a8b806
In the engraving mode, use the blank key to call the tools panel may suddenly disappear.
My native language text↓↓↓↓
在雕刻模式,使用空白鍵呼叫 tools 面板會有突然消失的可能。
  1. Set KeyMap>Spacebar Action>Tools
  2. Select any object and enter sculpt mode.
  3. Press the blank key to call the tools panel. At this time, the panel will suddenly disappear. (Error generation)
  4. Move the mouse arbitrarily
  5. Press the space button again to call the tools panel. At this time, the panel will suddenly disappear. (Error occurs again)
Other additional tests:
  1. The panel disappears (when an error occurs), do not move the mouse, press the blank key again, and it will appear normally
  1. When it appears normally, as long as you move the mouse and press the blank key, an error will occur, but there is one exception, which is simply moving the mouse horizontally so that the panel appears in the second position, the selected brush and slide The overlapping position of the mouse is exactly the same as the last time, the error will not occur (image)
  1. In the object mode, everything is normal, I think it should be operated like the object mode.
1.設定 KeyMap >Spacebar Action>Tools
2.選擇任意物體,進入sculpt模式。
3.按空白鍵呼叫tools面板。這時候面板會突然消失。(錯誤產生)
4.任意移動滑鼠
5.再次按空白鍵呼叫tools面板。這時候面板會突然消失。(再次錯誤產生)
其他額外測試 :
1.面板消失(錯誤產生時),滑鼠不要動,再按一次空白鍵,就可以正常出現
2.當正常出現後,只要有移動滑鼠,再按空白鍵就會發生錯誤,但有一個時候例外,就是單純水平移動滑鼠,讓第二個位置出現面板時,選取的筆刷與滑鼠重疊的位置和上一次一模一樣,錯誤就不會發生 (圖片)
3.在物體模式,一切正常,我認為應該操作起來要像物體模式這樣。
Pratik Borhade (PratikPB2123) changed the task status from Needs Triage to Confirmed.Jun 30 2021, 6:42 AM
Can confirm. (Also: replicable without interfering with the keymap settings)
I don’t know if I provided the question in this way. Is it correct? What information is needed?
